Microsoft Surface Pro 3 Headphone Jack Replacement
  1. Microsoft Surface Pro 3 Headphone Jack Replacement, Display: step 1, image 1 of 2 Microsoft Surface Pro 3 Headphone Jack Replacement, Display: step 1, image 2 of 2
    • Before you begin, discharge the Surface Pro's battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally damaged during the repair.
    • The display is strongly glued to the frame of the device.
    • To remove the display, first soften the adhesive by applying heat. You can use a heat pad, heat gun, or iOpener. In a pinch, a hair dryer can also work.
    • Be careful when using a heat gun, as too much heat can permanently damage the display and/or battery.
    • Steadily and evenly heat the perimeter of the display until it's too hot to touch, and try to maintain that temperature for several minutes.
  2. Microsoft Surface Pro 3 Headphone Jack Replacement: step 2, image 1 of 2 Microsoft Surface Pro 3 Headphone Jack Replacement: step 2, image 2 of 2
    • Use a suction cup or an iSclack to pull up on the glass and create a slight gap between the glass and the metal frame.
    • If your display is badly cracked, a suction cup may not adhere. It may help to first cover the display with a layer of packing tape. Alternatively, you can superglue your suction cup to the display.
    • Carefully insert an opening pick into the gap between the screen and the device to cut the adhesive.
    • Slide the pick around the sides and bottom of the display to cut the adhesive. Apply more heat as needed.
    • Work carefully—the glass is thin and will crack easily if you try to force it.
    • The wi-fi antennas are glued under the screen border along the top edge (on either side of the camera), and can be damaged easily. Use extra care when separating the top edge, and apply more heat if necessary.
  3. Microsoft Surface Pro 3 Headphone Jack Replacement: step 3, image 1 of 3 Microsoft Surface Pro 3 Headphone Jack Replacement: step 3, image 2 of 3 Microsoft Surface Pro 3 Headphone Jack Replacement: step 3, image 3 of 3
    • Continue to heat sections of the screen with the heat gun.
    • As you make your way around the screen with the heat gun, use the plastic opening tool and the opening picks to pry the screen loose.
    • The screen is extremely thin and very easy to break. Be careful working with broken glass.
  4. Microsoft Surface Pro 3 Headphone Jack Replacement: step 4, image 1 of 2 Microsoft Surface Pro 3 Headphone Jack Replacement: step 4, image 2 of 2
    • Lift the screen up carefully so that no wires are torn.
  5. Microsoft Surface Pro 3 Headphone Jack Replacement: step 5, image 1 of 2 Microsoft Surface Pro 3 Headphone Jack Replacement: step 5, image 2 of 2
    • Remove the 3 mm T3 Torx screw securing the battery connector, and disconnect the battery connector.
    • Be careful not lose the small, rectangular bridge connector that lies underneath.
  6. Microsoft Surface Pro 3 Headphone Jack Replacement: step 6, image 1 of 3 Microsoft Surface Pro 3 Headphone Jack Replacement: step 6, image 2 of 3 Microsoft Surface Pro 3 Headphone Jack Replacement: step 6, image 3 of 3
    • Remove the single 4 mm T3 Torx screw securing the display cable.
    • Lift the connector to disconnect the cable.
  7. Microsoft Surface Pro 3 Headphone Jack Replacement: step 7, image 1 of 3 Microsoft Surface Pro 3 Headphone Jack Replacement: step 7, image 2 of 3 Microsoft Surface Pro 3 Headphone Jack Replacement: step 7, image 3 of 3
    • Grasp the orange cable connected to the silver connecter.
    • Carefully lift the orange cable up until the connecter pops off.
    • The screen will now be completely disconnected.
    • The replacement display may not include all the parts needed for installation. Save all the parts from the original display, and transfer them to the new display as needed.
  8. Microsoft Surface Pro 3 Headphone Jack Replacement, Headphone Jack: step 8, image 1 of 2 Microsoft Surface Pro 3 Headphone Jack Replacement, Headphone Jack: step 8, image 2 of 2
    • Remove the single 4 mm T5 Torx screw.
    • Remove the four 4 mm T3 Torx screws.
    • Remove the single 7 mm T3 Torx screw.
  9. Microsoft Surface Pro 3 Headphone Jack Replacement: step 9, image 1 of 1
    • Remove the nut with the 4mm nut driver.
  10. Microsoft Surface Pro 3 Headphone Jack Replacement: step 10, image 1 of 2 Microsoft Surface Pro 3 Headphone Jack Replacement: step 10, image 2 of 2
    • Use the plastic opening tools to remove the black piece.
  11. Microsoft Surface Pro 3 Headphone Jack Replacement: step 11, image 1 of 1
    • Carefully remove the gray headphone jack.
  12. Microsoft Surface Pro 3 Headphone Jack Replacement: step 12, image 1 of 1
    • Use the metal spudger to remove the black ribbon wire from the device.
  13. Microsoft Surface Pro 3 Headphone Jack Replacement: step 13, image 1 of 1
    • Remove the two 4 mm T3 Torx screws.
  14. Microsoft Surface Pro 3 Headphone Jack Replacement: step 14, image 1 of 2 Microsoft Surface Pro 3 Headphone Jack Replacement: step 14, image 2 of 2
    • Finish removing the headphone jack using the metal spudger.
4 other people completed this guide.
Erik Snyder
5,240 Reputation
5 Guides authored
Cal Poly, Team 12-18, Maness Fall 2015 Member of Cal Poly, Team 12-18, Maness Fall 2015
CPSU-MANESS-F15S12G18
5 Members
31 Guides authored
One Comment
Very good instructions. But where is the difference between Headphone Jack Assembly with P/N
0801-35U00QS, 0801-35U01QS and 0801-2W900QS? On some of them is also X894488-001 printed in an extra row.
Daniel - Reply
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 17
All Time: 7,281
