Admiral AGD4675YQ3 Drum Belt Replacement
  1. Admiral AGD4675YQ3 Drum Belt Replacement, Drum Belt: step 1, image 1 of 1
    • Unplug the dryer's power cord.
  2. Admiral AGD4675YQ3 Drum Belt Replacement: step 2, image 1 of 1
    • Remove the lint catcher.
  3. Admiral AGD4675YQ3 Drum Belt Replacement: step 3, image 1 of 2 Admiral AGD4675YQ3 Drum Belt Replacement: step 3, image 2 of 2
    • When removing the screws, ensure that they do not fall into the lint chute. If this happens, a deeper disassembly will be required that this guide does not cover.
    • Use your Phillips #1 screwdriver and remove both 25.4 mm Phillips #1 screws.
  4. Admiral AGD4675YQ3 Drum Belt Replacement: step 4, image 1 of 2 Admiral AGD4675YQ3 Drum Belt Replacement: step 4, image 2 of 2
    • While keeping to the right corner, slip the butter knife in the slit above the dryer door.
    • If you cannot push the butter knife in, you are likely hitting the clip. Simply move the knife a bit more to the left till it slips in deep.
    • Pry up with moderate force and the clip holding the lid will pop up.
    • Repeat on the left side.
  5. Admiral AGD4675YQ3 Drum Belt Replacement: step 5, image 1 of 1
    • Fully lift the lid so that it stays in an upright position.
  6. Admiral AGD4675YQ3 Drum Belt Replacement: step 6, image 1 of 1
    • Disconnect the electrical harness on the right side.
  7. Admiral AGD4675YQ3 Drum Belt Replacement: step 7, image 1 of 2 Admiral AGD4675YQ3 Drum Belt Replacement: step 7, image 2 of 2
    • Remove the 18.4 mm hex cap screws on the left and right side with the 8 mm socket wrench.
    • Remove the clips underneath the screws on the left and right side.
  8. Admiral AGD4675YQ3 Drum Belt Replacement: step 8, image 1 of 2 Admiral AGD4675YQ3 Drum Belt Replacement: step 8, image 2 of 2
    • Using your thumb to hold the drum in place, pull the front panel of the dryer away from the drum.
    • There are two clips in the bottom left and right sides that will pop out when you pull.
    • Set the front panel to the side.
  9. Admiral AGD4675YQ3 Drum Belt Replacement: step 9, image 1 of 1
    • Place a shoebox sized item under the drum to hold the drum in place.
    • Keep the item as far to the left as possible so you will have room to work on the assembly underneath, located on the right.
  10. Admiral AGD4675YQ3 Drum Belt Replacement: step 10, image 1 of 3 Admiral AGD4675YQ3 Drum Belt Replacement: step 10, image 2 of 3 Admiral AGD4675YQ3 Drum Belt Replacement: step 10, image 3 of 3
    • If your drum belt has snapped, you can just pull the old belt out and proceed to step 13.
    • Grip the pulley bar and squeeze to push the pulley away from the drum.
    • Pull the belt off of the gear.
  11. Admiral AGD4675YQ3 Drum Belt Replacement: step 11, image 1 of 1
    • Remove the belt from the drum.
  12. Admiral AGD4675YQ3 Drum Belt Replacement: step 12, image 1 of 1
    • Place the new belt around the drum.
    • Make sure the grooved part of the belt is facing the grooved part of the drum.
    • The serial number and other identifying information on the belt should be facing up.
  13. Admiral AGD4675YQ3 Drum Belt Replacement: step 13, image 1 of 3 Admiral AGD4675YQ3 Drum Belt Replacement: step 13, image 2 of 3 Admiral AGD4675YQ3 Drum Belt Replacement: step 13, image 3 of 3
    • Form a loop with the belt and pull the loop under the pulley.
    • Squeeze the pulley bar and place the loop around the gear.
  14. Admiral AGD4675YQ3 Drum Belt Replacement: step 14, image 1 of 1
    • Rotate the drum counter clockwise and ensure the belt is covering the drum groove all the way around.
    • If the belt is out of place, simply tap it into place with your fingertips.
Clayton Biehunko
229 Reputation
1 Guide authored
One Comment
Gear? Drive spindle?
Frederick Kardatzke - Reply
Past 24 Hours: 3
Past 7 Days: 16
Past 30 Days: 63
All Time: 203
