Asus VivoTab Smart Speaker Replacement
  1. Asus VivoTab Smart Speaker Replacement, Speaker: step 1, image 1 of 3 Asus VivoTab Smart Speaker Replacement, Speaker: step 1, image 2 of 3 Asus VivoTab Smart Speaker Replacement, Speaker: step 1, image 3 of 3
    • Power off the device before you begin disassembly.
    • Place the device face down on a flat surface.
    • Remove the back panel with the plastic opening tool by sliding the tool around the edge of the panel.
  2. Asus VivoTab Smart Speaker Replacement: step 2, image 1 of 3 Asus VivoTab Smart Speaker Replacement: step 2, image 2 of 3 Asus VivoTab Smart Speaker Replacement: step 2, image 3 of 3
    Tool used on this step:
    Buy
    • Take care not to break the speaker wire when unplugging it from the device.
    • Carefully unplug the speaker wire from the device by grabbing the wire near the white plug with tweezers and pulling gently.
  3. Asus VivoTab Smart Speaker Replacement: step 3, image 1 of 2 Asus VivoTab Smart Speaker Replacement: step 3, image 2 of 2
    • Remove two 2.7 mm Phillips #00 screws.
    • Remove two 3.7 mm Phillips #00 screws.
  4. Asus VivoTab Smart Speaker Replacement: step 4, image 1 of 1
    • Remove the speaker from the device by lifting up on it.
Zach Hatten
548 Reputation
4 Guides authored
USF Tampa, Team 2-4, Sullivan Fall 2016 Member of USF Tampa, Team 2-4, Sullivan Fall 2016
USFT-SULLIVAN-F16S2G4
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 12
All Time: 339
