Craig CMP801 Battery Replacement
  1. Craig CMP801 Battery Replacement, Back Cover: step 1, image 1 of 2 Craig CMP801 Battery Replacement, Back Cover: step 1, image 2 of 2
    • Locate the opening line between the cover and the device. Then locate the groove near the charging port.
  2. Craig CMP801 Battery Replacement: step 2, image 1 of 2 Craig CMP801 Battery Replacement: step 2, image 2 of 2
    • Use a metal spudger to separate the back cover from the front touch screen.
    • To do this, place the metal spudger in between the groove near the charging port of the device to unlatch the first clip.
  3. Craig CMP801 Battery Replacement: step 3, image 1 of 2 Craig CMP801 Battery Replacement: step 3, image 2 of 2
    • Continue to separate all of the clips around the device until the back cover comes off completely.
  4. Craig CMP801 Battery Replacement, Battery: step 4, image 1 of 3 Craig CMP801 Battery Replacement, Battery: step 4, image 2 of 3 Craig CMP801 Battery Replacement, Battery: step 4, image 3 of 3
    • Locate the white plug next to the battery.
    • Use your fingers to pull off white plug that connected to the battery.
    • Be careful not to pull or break the wires on the bottom.
  5. Craig CMP801 Battery Replacement: step 5, image 1 of 3 Craig CMP801 Battery Replacement: step 5, image 2 of 3 Craig CMP801 Battery Replacement: step 5, image 3 of 3
    • The battery should only be connected to the LCD by adhesive tape.
    • Using force, carefully remove the battery while holding the LCD in place.
One Comment
Where do I find a battery cmp749 ???
kourriclay929 - Reply
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 23
All Time: 1,018
