Dell Axim X30 Screen Replacement
  1. Dell Axim X30 Screen Replacement, Screen: step 1, image 1 of 3 Dell Axim X30 Screen Replacement, Screen: step 1, image 2 of 3 Dell Axim X30 Screen Replacement, Screen: step 1, image 3 of 3
    • Remove the four rubber feet with your fingers.
  2. Dell Axim X30 Screen Replacement: step 2, image 1 of 2 Dell Axim X30 Screen Replacement: step 2, image 2 of 2
    • Trigger battery release by inserting a nylon spudger into the battery release tab.
    • Slide tab and pull upwards on the battery to remove. Use the finger slots near the battery.
  3. Dell Axim X30 Screen Replacement: step 3, image 1 of 1
    • Remove the four 12.7mm screws under rubber feet with a JIS #0 screwdriver.
  4. Dell Axim X30 Screen Replacement: step 4, image 1 of 1
    • Remove back panel with a plastic opening tool. Follow the edge of the device around the entire perimeter.
    • The back panel should just pop off.
  5. Dell Axim X30 Screen Replacement: step 5, image 1 of 3 Dell Axim X30 Screen Replacement: step 5, image 2 of 3 Dell Axim X30 Screen Replacement: step 5, image 3 of 3
    • Disconnect ribbon cables.
    • You may need to use a little force to disconnect them.
    • Disconnect red and white wired connector for speaker and motherboard battery.
  6. Dell Axim X30 Screen Replacement: step 6, image 1 of 2 Dell Axim X30 Screen Replacement: step 6, image 2 of 2
    • Remove three 12.7mm JIS #0 screws.
  7. Dell Axim X30 Screen Replacement: step 7, image 1 of 1
    • Carefully remove motherboard.
  8. Dell Axim X30 Screen Replacement: step 8, image 1 of 2 Dell Axim X30 Screen Replacement: step 8, image 2 of 2
    • Remove the two 9.6 mm screws by the speaker and green battery with a JIS #0 screwdriver.
  9. Dell Axim X30 Screen Replacement: step 9, image 1 of 2 Dell Axim X30 Screen Replacement: step 9, image 2 of 2
    • Remove black plastic board.
  10. Dell Axim X30 Screen Replacement: step 10, image 1 of 2 Dell Axim X30 Screen Replacement: step 10, image 2 of 2
    • Gently apply pressure on the right plastic frame by plastic clip marked on the picture.
    • Apply pressure to the bottom of the screen and press it towards you.
    • Remove screen from plastic case.
Peter Reilly
196 Reputation
1 Guide authored
IUPUI, Team S2-G5, Harley Spring 2018 Member of IUPUI, Team S2-G5, Harley Spring 2018
IUPUI-HARLEY-S18S2G5
3 Members
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 18
All Time: 782
