Disassembling Samsung ATIV Smart PC 500T Backplate
  1. Disassembling Samsung ATIV Smart PC 500T Backplate, Backplate: step 1, image 1 of 2 Disassembling Samsung ATIV Smart PC 500T Backplate, Backplate: step 1, image 2 of 2
    • Remove the stylus from the device.
    • Place the device screen-up on a hard surface, like a table.
  2. Disassembling Samsung ATIV Smart PC 500T Backplate: step 2, image 1 of 3 Disassembling Samsung ATIV Smart PC 500T Backplate: step 2, image 2 of 3 Disassembling Samsung ATIV Smart PC 500T Backplate: step 2, image 3 of 3
    • Insert a plastic pry tool or opening pick between the glass and plastic case.
    • Work your way around the plastic edge, unclipping the backplate.
    • Once the clips are loosened, remove the backplate. Some force may be necessary.
    • Though you may need to use force, be careful of the pry tool slipping and hurting you!
9 other people completed this guide.
Crystal Dinh
1,026 Reputation
4 Guides authored
Baylor, Team 6-6, Williams Fall 2015 Member of Baylor, Team 6-6, Williams Fall 2015
BU-WILLIAMS-F15S6G6
3 Members
10 Guides authored
2 Comments
Samsung tablet xe500t1c partition missing problem
waheed - Reply
Partition do not show
x drive show
waheed - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 21
All Time: 3,751
