Fujitsu Lifebook Stylistic Q584 Buttons Replacement
  1. Fujitsu Lifebook Stylistic Q584 Buttons  Replacement, Back Case: step 1, image 1 of 1
    • Remove the white sticker covering the screws (if applicable).
    • Use the PH1 screwdriver to remove the four 2 mm screws from the the backside of the device.
  2. Fujitsu Lifebook Stylistic Q584 Buttons  Replacement: step 2, image 1 of 1
    • Insert the plastic opening tool along the seam of the back case.
    • Gently slide the plastic opening tool along the entire seam popping the clips free.
  3. Fujitsu Lifebook Stylistic Q584 Buttons  Replacement: step 3, image 1 of 1
    • Carefully lift the back case and remove the smartcard ribbon from the motherboard.
  4. Fujitsu Lifebook Stylistic Q584 Buttons  Replacement, Buttons: step 4, image 1 of 1
    • Locate the plastic buttons on left side of the device.
  5. Fujitsu Lifebook Stylistic Q584 Buttons  Replacement: step 5, image 1 of 1
    • Gently remove the plastic buttons.
Connor Stanton
613 Reputation
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 16
All Time: 384
