How to Repair the Lining of a Canvas Shoe with an Iron-On Patch
  1. How to Repair the Lining of a Canvas Shoe with an Iron-On Patch, How to Repair the Lining of a Canvas Shoe with an Iron-On Patch: step 1, image 1 of 1
    • Identify the hole or tear in your canvas shoe.
  2. How to Repair the Lining of a Canvas Shoe with an Iron-On Patch: step 2, image 1 of 2 How to Repair the Lining of a Canvas Shoe with an Iron-On Patch: step 2, image 2 of 2
    • Preheat the iron to the highest setting without steam. In most cases this will be the cotton or linen setting.
    • If your iron does not have an on/off setting for steam, make sure there is no water in the water compartment when starting the project.
    • Always exercise caution when working around a hot iron.
  3. How to Repair the Lining of a Canvas Shoe with an Iron-On Patch: step 3, image 1 of 3 How to Repair the Lining of a Canvas Shoe with an Iron-On Patch: step 3, image 2 of 3 How to Repair the Lining of a Canvas Shoe with an Iron-On Patch: step 3, image 3 of 3
    • Unlace the shoe so you can reach the hole better.
  4. How to Repair the Lining of a Canvas Shoe with an Iron-On Patch: step 4, image 1 of 2 How to Repair the Lining of a Canvas Shoe with an Iron-On Patch: step 4, image 2 of 2
    • Cut away loose threads and frayed edges to leave a smooth surface for the patch to adhere to.
  5. How to Repair the Lining of a Canvas Shoe with an Iron-On Patch: step 5, image 1 of 3 How to Repair the Lining of a Canvas Shoe with an Iron-On Patch: step 5, image 2 of 3 How to Repair the Lining of a Canvas Shoe with an Iron-On Patch: step 5, image 3 of 3
    • Measure and cut patch to slightly larger than the size of the hole, this can be eye-balled.
  6. How to Repair the Lining of a Canvas Shoe with an Iron-On Patch: step 6, image 1 of 2 How to Repair the Lining of a Canvas Shoe with an Iron-On Patch: step 6, image 2 of 2
    • Lay a towel down to protect your work surface while ironing.
  7. How to Repair the Lining of a Canvas Shoe with an Iron-On Patch: step 7, image 1 of 2 How to Repair the Lining of a Canvas Shoe with an Iron-On Patch: step 7, image 2 of 2
    • Make sure the patch is as flat as possible against the shoe.
    • Iron over the patch for 60 seconds.
    • If you see or smell any smoke, stop ironing immediately. Your iron may be too hot.
  8. How to Repair the Lining of a Canvas Shoe with an Iron-On Patch: step 8, image 1 of 1
    • Roll your towel tightly so it will fit inside your shoe.
  9. How to Repair the Lining of a Canvas Shoe with an Iron-On Patch: step 9, image 1 of 3 How to Repair the Lining of a Canvas Shoe with an Iron-On Patch: step 9, image 2 of 3 How to Repair the Lining of a Canvas Shoe with an Iron-On Patch: step 9, image 3 of 3
    • Use the rolled towel to support the shoe where you just ironed the patch.
    • Iron the location of the patch from the other side for 30 seconds.
  10. How to Repair the Lining of a Canvas Shoe with an Iron-On Patch: step 10, image 1 of 1
    • Let the patch cool before use.
Try on your shoe. If there are edges that are not flattened, iron on a lower heat for 30 seconds on those spots. Be careful not to heat the patch too much, as the glue on the patch could dry out. Once cooled, re-lace the shoe, and it will be ready to wear again!
If you desire extra security, you can reinforce your patch using this guide.
Abigail Lodge
181 Reputation
1 Guide authored
UC Davis, Team 4-3, Andersen Winter 2023 Member of UC Davis, Team 4-3, Andersen Winter 2023
UCD-ANDERSEN-W23S4G3
3 Members
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 12
Past 30 Days: 57
All Time: 795
