Irulu walknbook Windows 10 tablet battery Replacement
  1. Irulu walknbook Windows 10 tablet  battery Replacement, battery: step 1, image 1 of 1
    • this is what you should end up like with the tab
  2. Irulu walknbook Windows 10 tablet  battery Replacement: step 2, image 1 of 1
    • first remove the orange (or other colour) bezels from the side of the tab. the all have a small hole grip.
  3. Irulu walknbook Windows 10 tablet  battery Replacement: step 3, image 1 of 1
    • on the back cover there is a glass cover that covers up the screws. be carefull when removing it because it might break. use small like credit cards to seperate it but still be very carefull.
  4. Irulu walknbook Windows 10 tablet  battery Replacement: step 4, image 1 of 1
    • so the back cover seperates in to two parts. after removing the glass part the screws are visible. remove all of them. the back cover can pe removed very easily.
  5. Irulu walknbook Windows 10 tablet  battery Replacement: step 5, image 1 of 1
    • you then end up with all the rest of the internal parts visible. now you can replace the battery or the display. there is also a 3g port slot but i haven't tried it out yet. let me know if this worked for you.
6 other people completed this guide.
Dili
242 Reputation
1 Guide authored
11 Comments
Hey I have another question is it possible to replace the ram in it or no
jackroc21 - Reply
No that is not possible because the ram is soldered on the main board.
Dili -
where can I buy a replacement battery for this walknbook????
hushpuppy43 - Reply
Donde puedo comprar la batería ,no la encuentro.
will5551970 - Reply
Necesito comprar la batería para la irulu
Battery:7800 mAh irulu w1002
Donde la venden.
will5551970 - Reply
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 26
All Time: 5,621
