Michael Kors Watch Link Band Replacement
  1. Michael Kors Watch Link Band Replacement, Link Band: step 1, image 1 of 1
    • Place the watch on your wrist and determine whether links should be added or removed.
    • If watchband needs to be expanded, approximate the number of links required.
  2. Michael Kors Watch Link Band Replacement: step 2, image 1 of 3 Michael Kors Watch Link Band Replacement: step 2, image 2 of 3 Michael Kors Watch Link Band Replacement: step 2, image 3 of 3
    • Set the watch on the block holder.
    • Ensure the arrows located on the links are pointing downward.
  3. Michael Kors Watch Link Band Replacement: step 3, image 1 of 1
    • When removing damaged or extra links, hold one end of the pin pusher against the pin to be removed.
    • Strike the other end of the pin pusher with the metal side of the watch hammer until the pin slides out.
    • Two pins hold each link to the band, so two pins must be removed per link.
  4. Michael Kors Watch Link Band Replacement: step 4, image 1 of 1
    • Discard the broken links or save any extra links that you remove.
  5. Michael Kors Watch Link Band Replacement: step 5, image 1 of 2 Michael Kors Watch Link Band Replacement: step 5, image 2 of 2
    • To add links to the watchband, position the watch on the block holder with the arrows facing upward.
    • Insert pins into the holes that connect the new link to the rest of the watchband.
    • Use the soft side of the hammer to strike the pin down.
  6. Michael Kors Watch Link Band Replacement: step 6, image 1 of 2 Michael Kors Watch Link Band Replacement: step 6, image 2 of 2
    • Lastly, make sure that all the pins joining the links are secured in place.
7 other people completed this guide.
9 Comments
How do I replace a broken link when it's the very first link that connects the band to the actual watch?
Karen Perri - Reply
How can I puchace the first link on my Michael kors ceramic watch
melissa.costello31 -
I need first link to attach to micheal kors ceramic white watch
The lady when I bought my watch at the mall told me that Michael Kors will give you two free links I'm trying to figure out how I can go about getting that
Claudia Mead - Reply
Where can I get the white bands that cover the links on my my watch as a few have bits broken
Karenclemo@gmail.com - Reply
Past 24 Hours: 7
Past 7 Days: 55
Past 30 Days: 251
All Time: 77,129
