Repairing nose pads on eyeglasses
  1. Repairing nose pads on eyeglasses, Repairing nose pads on eyeglasses: step 1, image 1 of 2 Repairing nose pads on eyeglasses, Repairing nose pads on eyeglasses: step 1, image 2 of 2
    • Remove the screw from the pad arm.
    • If the screw is missing, get a backup screw, and proceed to step 2.
  2. Repairing nose pads on eyeglasses: step 2, image 1 of 2 Repairing nose pads on eyeglasses: step 2, image 2 of 2
    • Insert the nose pad into the mount on the frame.
    • Make sure the nose pad lines up with the screw hole.
    • While holding the nose pad in place, use the magnet to attract the screw head.
    • Make sure the screw is vertical to the magnet and the screw head is above.
  3. Repairing nose pads on eyeglasses: step 3, image 1 of 1
    • Place the screw into the screw hole.
  4. Repairing nose pads on eyeglasses: step 4, image 1 of 2 Repairing nose pads on eyeglasses: step 4, image 2 of 2
    • Using a horizontal motion, remove the magnet.
    • Don't use a vertical motion to remove the magnet, otherwise the screw will come out.
  5. Repairing nose pads on eyeglasses: step 5, image 1 of 2 Repairing nose pads on eyeglasses: step 5, image 2 of 2
    • Holding the glasses with the screw head pointing up, tighten the screw with the screwdriver.
    • Make sure the screw is tightened enough.
3 other people completed this guide.
Vivi Chou
151 Reputation
1 Guide authored
UC Davis, Team S3-G4, Coad Spring 2017 Member of UC Davis, Team S3-G4, Coad Spring 2017
UCD-COAD-S17S3G4
3 Members
3 Guides authored
0 Comments
Past 24 Hours: 10
Past 7 Days: 74
Past 30 Days: 314
All Time: 46,679
