Rubber Watch Battery Replacement
  1. Rubber Watch Battery Replacement, Battery: step 1, image 1 of 2 Rubber Watch Battery Replacement, Battery: step 1, image 2 of 2
    • Begin by placing the watch on its backside.
  2. Rubber Watch Battery Replacement: step 2, image 1 of 3 Rubber Watch Battery Replacement: step 2, image 2 of 3 Rubber Watch Battery Replacement: step 2, image 3 of 3
    • Gently pull the top of the watch's back until the cap detaches, in a peeling motion.
    • Pull out the white cap and green chip once it is free.
  3. Rubber Watch Battery Replacement: step 3, image 1 of 1
    • Carefully puncture the plastic casing next to the battery on top of the green chip with the X-Acto knife and stop.
    • Be careful not to insert the X-Acto knife too downward into the battery.
  4. Rubber Watch Battery Replacement: step 4, image 1 of 3 Rubber Watch Battery Replacement: step 4, image 2 of 3 Rubber Watch Battery Replacement: step 4, image 3 of 3
    • Flip the chip around to the front.
    • In a chiseling motion, make an incision on the front side above the battery to cut out a plastic casing.
    • Make sure to hold the knife away from the hands in a safe, stable grip.
    • Remove the cut plastic casing over the battery.
    • The plastic casing should come off like a cap.
  5. Rubber Watch Battery Replacement: step 5, image 1 of 1
    • Gently remove the battery with a spudger or a wooden coffee stick.
    • Using too much force may detach the tab holding the battery and break the watch.
    • Once free, remove the dead battery.
  6. Rubber Watch Battery Replacement: step 6, image 1 of 1
    • Insert the new battery.
    • Place the cut plastic cap casing over the chip and battery.
  7. Rubber Watch Battery Replacement: step 7, image 1 of 3 Rubber Watch Battery Replacement: step 7, image 2 of 3 Rubber Watch Battery Replacement: step 7, image 3 of 3
    • Place the white cap over the green chip.
    • Insert the white cap and green chip into the back of the watch with the spudger or wooden coffee stick.
    • Turn over the watch and check the power.
Finish Line
Lee
110 Reputation
1 Guide authored
UC Davis, Team S2-G5, Cole Spring 2017 Member of UC Davis, Team S2-G5, Cole Spring 2017
UCD-COLE-S17S2G5
3 Members
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 14
All Time: 772
