Samsung Galaxy TabPro S Rear Facing Camera Replacement
  1. Samsung Galaxy TabPro S Rear Facing Camera Replacement, Rear Facing Camera: step 1, image 1 of 1
    • Place the device face down on a flat work surface.
  2. Samsung Galaxy TabPro S Rear Facing Camera Replacement: step 2, image 1 of 2 Samsung Galaxy TabPro S Rear Facing Camera Replacement: step 2, image 2 of 2
    • Heat the iOpener in the microwave for 30 seconds. Then place it on each side for 20 seconds in order to loosen the adhesive sealing on the device.
  3. Samsung Galaxy TabPro S Rear Facing Camera Replacement: step 3, image 1 of 3 Samsung Galaxy TabPro S Rear Facing Camera Replacement: step 3, image 2 of 3 Samsung Galaxy TabPro S Rear Facing Camera Replacement: step 3, image 3 of 3
    • Using the plastic spudger, open up the back of the device.
  4. Samsung Galaxy TabPro S Rear Facing Camera Replacement: step 4, image 1 of 1
    • Locate the camera and its corresponding connecting port.
  5. Samsung Galaxy TabPro S Rear Facing Camera Replacement: step 5, image 1 of 3 Samsung Galaxy TabPro S Rear Facing Camera Replacement: step 5, image 2 of 3 Samsung Galaxy TabPro S Rear Facing Camera Replacement: step 5, image 3 of 3
    Tool used on this step:
    Buy
    • Using tweezers carefully peel off the sticker.
  6. Samsung Galaxy TabPro S Rear Facing Camera Replacement: step 6, image 1 of 2 Samsung Galaxy TabPro S Rear Facing Camera Replacement: step 6, image 2 of 2
    • Using the black nylon spudger, flip the top half of the connecting port downward until you hear a click.
  7. Samsung Galaxy TabPro S Rear Facing Camera Replacement: step 7, image 1 of 1
    • Proceed to lift up the camera out of its resting position.
  8. Samsung Galaxy TabPro S Rear Facing Camera Replacement: step 8, image 1 of 2 Samsung Galaxy TabPro S Rear Facing Camera Replacement: step 8, image 2 of 2
    • Simply pull the camera parallel to the device out of its connecting port.
2 other people completed this guide.
Jyotsna Gone
515 Reputation
2 Guides authored
USF Tampa, Team 1-2, Sullivan Spring 2017 Member of USF Tampa, Team 1-2, Sullivan Spring 2017
USFT-SULLIVAN-S17S1G2
4 Members
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 11
All Time: 1,546
