Samsung Galaxy TabPro S Screen Replacement
  1. Samsung Galaxy TabPro S Screen Replacement, Screen: step 1, image 1 of 1
    • Apply heat around the screen to loosen the glue holding in the screen. A heat gun would be preferable as it needs to get relatively warm.
  2. Samsung Galaxy TabPro S Screen Replacement: step 2, image 1 of 1
    • Attach the small suction cup near the edge of the screen.
    • Pry in between the screen and the frame with a plastic spudger.
    • Pull up with the suction cup while prying and the screen should begin gently disconnecting.
    • Use the spudger on all edges of the tablet between the screen and the frame.
    • The screen should release.
  3. Samsung Galaxy TabPro S Screen Replacement: step 3, image 1 of 1
    • Disconnect the thick cable from the motherboard
    • Disconnect the golden cable from the motherboard
Mitchell Caister
328 Reputation
3 Guides authored
IUPUI, Team 3-4, Harley Spring 2022 Member of IUPUI, Team 3-4, Harley Spring 2022
IUPUI-HARLEY-S22S3G4
3 Members
3 Guides authored
One Comment
Where to find a replacement screen for a 2017 Samsung tab S pro 12 inch ?!?!?
ori gosi - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 19
All Time: 768
