Two-Hole Button Replacement
  1. Two-Hole Button Replacement, Two-Hole Button: step 1, image 1 of 1
    • Choose a thread that will match the rest of the buttons on the jacket/button.
  2. Two-Hole Button Replacement: step 2, image 1 of 1
    • Thread the needle so that there is equal thread on both sides of the needle.
  3. Two-Hole Button Replacement: step 3, image 1 of 2 Two-Hole Button Replacement: step 3, image 2 of 2
    • Tie a knot at the end of the thread so that it will not come back through the buttonhole.
  4. Two-Hole Button Replacement: step 4, image 1 of 1
    • Place the button on the fabric that you are sewing it back on to.
  5. Two-Hole Button Replacement: step 5, image 1 of 2 Two-Hole Button Replacement: step 5, image 2 of 2
    • Take the threaded needle and push it through the fabric and one of the buttonholes on the bottom side and pull it through.
  6. Two-Hole Button Replacement: step 6, image 1 of 2 Two-Hole Button Replacement: step 6, image 2 of 2
    • Thread the needle down through the second hole of the button.
  7. Two-Hole Button Replacement: step 7, image 1 of 1
    • Place a straight pin on the backside of the button to keep the button from being sewn on too tight.
  8. Two-Hole Button Replacement: step 8, image 1 of 2 Two-Hole Button Replacement: step 8, image 2 of 2
    • Repeat steps 5-6 to continue sewing the button on until secure.
  9. Two-Hole Button Replacement: step 9, image 1 of 2 Two-Hole Button Replacement: step 9, image 2 of 2
    • Once the button is secure, push the needle through the fabric but not the button and remove the pin.
  10. Two-Hole Button Replacement: step 10, image 1 of 2 Two-Hole Button Replacement: step 10, image 2 of 2
    • Once the pin is removed, wrap the thread around the button 6-7 times and push the needle through the fabric on the underside of the button.
  11. Two-Hole Button Replacement: step 11, image 1 of 3 Two-Hole Button Replacement: step 11, image 2 of 3 Two-Hole Button Replacement: step 11, image 3 of 3
    • To finish sewing, make 3-4 stitches to tie off.
  12. Two-Hole Button Replacement: step 12, image 1 of 3 Two-Hole Button Replacement: step 12, image 2 of 3 Two-Hole Button Replacement: step 12, image 3 of 3
    • Cut the remaining thread off.
Test out your fix by closing the jacket/clothing item with your resewn button!
0 Comments
Past 24 Hours: 4
Past 7 Days: 6
Past 30 Days: 30
All Time: 117
