Unbranded UB-15MS10 Screen Replacement
  1. Unbranded UB-15MS10 Screen Replacement, Screen: step 1, image 1 of 1
    • Use an opening tool to pry off the lid of the memory card compartment.
  2. Unbranded UB-15MS10 Screen Replacement: step 2, image 1 of 1
    • Use a Phillips #00 Screwdriver to unscrew the two 1.2mm screws within the compartment. This allows the device to be opened.
  3. Unbranded UB-15MS10 Screen Replacement: step 3, image 1 of 2 Unbranded UB-15MS10 Screen Replacement: step 3, image 2 of 2
    • Insert opening tools to partially pry open the cover.
  4. Unbranded UB-15MS10 Screen Replacement: step 4, image 1 of 1
    • With the cover being partially held open, slide a spudger around the seam to pry off the cover.
  5. Unbranded UB-15MS10 Screen Replacement: step 5, image 1 of 1
    • Remove the tape that is holding the battery in place.
  6. Unbranded UB-15MS10 Screen Replacement: step 6, image 1 of 1
    • Unscrew the five 1.2mm screws that connect the circuit board to the device.
  7. Unbranded UB-15MS10 Screen Replacement: step 7, image 1 of 1
    • There are three silver tabs around the internal components that connect it to the frame with screws. Unscrew these screws to remove the internal components.
  8. Unbranded UB-15MS10 Screen Replacement: step 8, image 1 of 1
    • Carefully lift the internal components from the screen and place them into a replacement screen.
To reassemble your device, follow instructions 1-7 in reverse order.
2 other people completed this guide.
Evan Peterson
320 Reputation
2 Guides authored
One Comment
All the instruction are fine to follow except the last one, step 8. What tool to use to lift the internal components from the screen frame or where to start to lift without damage to the internal components?
Alfred H. Schaefer - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 14
All Time: 1,932
