Westcott iPoint Evolution Outer Casing Replacement
  1. Westcott iPoint Evolution Outer Casing Replacement, Outer Casing: step 1, image 1 of 1
    • Step 1: Start with the back of the pencil sharpener facing you.
    • This allows you to locate the power source.
  2. Westcott iPoint Evolution Outer Casing Replacement: step 2, image 1 of 1
    • Step 2: Grab the end of the plug located at the bottom of the sharpener and pull it out gently.
  3. Westcott iPoint Evolution Outer Casing Replacement: step 3, image 1 of 2 Westcott iPoint Evolution Outer Casing Replacement: step 3, image 2 of 2
    • There are three parts of the sharpener.
    • Step 3: Grab the very top of the sharpener, twist it to the right and lift it up to remove it.
  4. Westcott iPoint Evolution Outer Casing Replacement: step 4, image 1 of 3 Westcott iPoint Evolution Outer Casing Replacement: step 4, image 2 of 3 Westcott iPoint Evolution Outer Casing Replacement: step 4, image 3 of 3
    • Step 4: Grab the center of the sharpener and lift it up to remove the piece.
  5. Westcott iPoint Evolution Outer Casing Replacement: step 5, image 1 of 3 Westcott iPoint Evolution Outer Casing Replacement: step 5, image 2 of 3 Westcott iPoint Evolution Outer Casing Replacement: step 5, image 3 of 3
    • Step 5: Remove the small ring that is around the sharpener.
    • This piece is below the center of the sharpener that you just removed.
  6. Westcott iPoint Evolution Outer Casing Replacement: step 6, image 1 of 1
    • Step 6: Flip the pencil sharpener upside down.
    • Locate the four screws on the bottom of the sharpener.
  7. Westcott iPoint Evolution Outer Casing Replacement: step 7, image 1 of 1
    • Step 7: Take a screwdriver and unscrew all of the screws on the bottom.
  8. Westcott iPoint Evolution Outer Casing Replacement: step 8, image 1 of 1
    • Step 8: After all the screws are removed gently take off the bottom of the sharpener.
  9. Westcott iPoint Evolution Outer Casing Replacement: step 9, image 1 of 1
    • Step 9: Carefully lift the lid off of the sharpener.
3 other people completed this guide.
0 Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 41
All Time: 11,788
