Xbox One Wireless Controller Model 1708 Top Motherboard Replacement
  1. Xbox One Wireless Controller Model 1708 Top Motherboard Replacement, Cover Plate: step 1, image 1 of 2 Xbox One Wireless Controller Model 1708 Top Motherboard Replacement, Cover Plate: step 1, image 2 of 2
    • Slide the battery cover toward the top of the controller to remove it.
    • Lift up the batteries or the battery pack from the battery compartment.
  2. Xbox One Wireless Controller Model 1708 Top Motherboard Replacement: step 2, image 1 of 2 Xbox One Wireless Controller Model 1708 Top Motherboard Replacement: step 2, image 2 of 2
    • Insert a plastic opening tool into the top seam, and gently work the opening tool to the bottom of the controller.
    • Continue using the opening tool to gently pry the side plate off of the controller.
    • Repeat this process for the second side plate.
  3. Xbox One Wireless Controller Model 1708 Top Motherboard Replacement: step 3, image 1 of 1
    • Gently peel the battery label or punch a hole in the center of the sticker in the battery compartment to reveal the hidden screw.
    • Remove the five 9mm torx-9 security screws from the back of the controller.
  4. Xbox One Wireless Controller Model 1708 Top Motherboard Replacement, Tape Shock Motors in place: step 4, image 1 of 3 Xbox One Wireless Controller Model 1708 Top Motherboard Replacement, Tape Shock Motors in place: step 4, image 2 of 3 Xbox One Wireless Controller Model 1708 Top Motherboard Replacement, Tape Shock Motors in place: step 4, image 3 of 3
    • Tape the Rumbler/shock motors in place.
    • This will prevent the motors from falling out.
  5. Xbox One Wireless Controller Model 1708 Top Motherboard Replacement: step 5, image 1 of 2 Xbox One Wireless Controller Model 1708 Top Motherboard Replacement: step 5, image 2 of 2
    • Orient the controller so the front plate is facing up.
    • Lift the front cover off of the controller.
  6. Xbox One Wireless Controller Model 1708 Top Motherboard Replacement: step 6, image 1 of 1
    • Turn the controller face down and gently lift the rear plate.
    • Be careful with the rumble motors, as they tend to fall out, risking damage to the motherboard.
  7. Xbox One Wireless Controller Model 1708 Top Motherboard Replacement, Directional Pad: step 7, image 1 of 1
    • Turn the device over and remove the directional pad by gently pulling it away from the controller.
  8. Xbox One Wireless Controller Model 1708 Top Motherboard Replacement, Joystick Caps: step 8, image 1 of 1
    • Pull the joysticks off of the controller.
  9. Xbox One Wireless Controller Model 1708 Top Motherboard Replacement, Top Motherboard: step 9, image 1 of 1
    • If the rumble motors fall out of frame, the wires may disconnect from the motherboard . The wires will have to be soldered to reattach the motor.
    • Turn the device over and remove the two 7mm torx-6 screws in the bottom left and right corners.
  10. Xbox One Wireless Controller Model 1708 Top Motherboard Replacement, De-soldering required: step 10, image 1 of 3 Xbox One Wireless Controller Model 1708 Top Motherboard Replacement, De-soldering required: step 10, image 2 of 3 Xbox One Wireless Controller Model 1708 Top Motherboard Replacement, De-soldering required: step 10, image 3 of 3
    • Firmly grasp the top and bottom motherboards in opposite hands, then gently pull them apart.
    • The top motherboard is still connected to the bottom motherboard. To fully separate the top motherboard, you will need to use a soldering iron.
    • Warning: Do not attempt to disconnect the shielded (gold colored) connector as it is extremely fragile you will break it. It runs between the two boards.
    • De-solder the shielded cable from the lower board instead of attempting to disconnect the connector. De-solder using micro soldering techniquest.
20 other people completed this guide.
Lien (Ally) Quan
918 Reputation
1 Guide authored
Cal Poly, Team S18-G3, Forte Fall 2017 Member of Cal Poly, Team S18-G3, Forte Fall 2017
CPSU-FORTE-F17S18G3
4 Members
32 Guides authored
0 Comments
Past 24 Hours: 10
Past 7 Days: 90
Past 30 Days: 359
All Time: 25,110
