Window Operator Link Replacement
  1. Window Operator Link Replacement, Link: step 1, image 1 of 2 Window Operator Link Replacement, Link: step 1, image 2 of 2
    Tool used on this step:
    Flathead 4 mm Screwdriver
    $5.49
    Buy
    • Remove the four (4) window clips that holds the screen.
    • Your amount of window clips may vary depending on the size of your window.
    • Use the Flathead 4 mm Screwdriver to loosen the clip. The clip doesn't need to be removed.
    • Remove the screen and put it aside.
  2. Window Operator Link Replacement: step 2, image 1 of 3 Window Operator Link Replacement: step 2, image 2 of 3 Window Operator Link Replacement: step 2, image 3 of 3
    Large Needle Nose Pliers
    Buy
  3. Window Operator Link Replacement: step 3, image 1 of 3 Window Operator Link Replacement: step 3, image 2 of 3 Window Operator Link Replacement: step 3, image 3 of 3
    • Using the Phillips #2 Screwdriver , remove the two bolts that are holding the operator into the window frame.
    • Behind the window, you will have one self retaining nut per bolt.
    • In some cases, you will need to play with the operator in order to take it out due to the small tolerances in the window.
  4. Window Operator Link Replacement: step 4, image 1 of 3 Window Operator Link Replacement: step 4, image 2 of 3 Window Operator Link Replacement: step 4, image 3 of 3
    Metal Spudger
    $2.99
    Buy
  5. Window Operator Link Replacement: step 5, image 1 of 3 Window Operator Link Replacement: step 5, image 2 of 3 Window Operator Link Replacement: step 5, image 3 of 3
    Buy
    • Once the warped or broken link is removed, follow the Step 4 in reverse order.
    • You may use the Large Needle Nose Pliers to force the e-clip into place.
To reassemble your device, follow from step three (3) to one (1) in reverse order.
0 Comments
Past 24 Hours: 3
Past 7 Days: 13
Past 30 Days: 36
All Time: 862
