Xbox One Elite Controller (Model 1698) Buttons Replacement
  1. Xbox One Elite Controller (Model 1698) Buttons Replacement, Battery: step 1, image 1 of 1
    • Turn over the controller so that the buttons face down.
    • Be gentle when removing the cover so you do not break the small plastic tabs holding the cover to the controller.
    • Remove the battery cover carefully by sliding the cover up in the direction of the arrow.
  2. Xbox One Elite Controller (Model 1698) Buttons Replacement: step 2, image 1 of 2 Xbox One Elite Controller (Model 1698) Buttons Replacement: step 2, image 2 of 2
    • Remove the two batteries AA batteries by lifting them from one end and pulling them out.
  3. Xbox One Elite Controller (Model 1698) Buttons Replacement, Rumble Motor: step 3, image 1 of 3 Xbox One Elite Controller (Model 1698) Buttons Replacement, Rumble Motor: step 3, image 2 of 3 Xbox One Elite Controller (Model 1698) Buttons Replacement, Rumble Motor: step 3, image 3 of 3
    • Be careful not to break the plastic tabs, that hold each grip cover to the back of the controller.
    • Remove each grip by inserting the plastic opening tool near the top of the controller.
    • Guide the plastic opening tool along the entire seam and gently separate the grip from the controller in a prying motion as you go.
  4. Xbox One Elite Controller (Model 1698) Buttons Replacement: step 4, image 1 of 2 Xbox One Elite Controller (Model 1698) Buttons Replacement: step 4, image 2 of 2
    • Remove the five 2.3 mm screws with the TR8 Torx Security screwdriver.
    • Four of the screws are located at the bottom tip of each grip and at the top of each grip, near the triggers of the controller.
    • The last screw is located in the center of the battery tray beneath a sticker.
    • Use a TR8 Torx Security Screwdriver to puncture the sticker and remove the final screw.
  5. Xbox One Elite Controller (Model 1698) Buttons Replacement: step 5, image 1 of 3 Xbox One Elite Controller (Model 1698) Buttons Replacement: step 5, image 2 of 3 Xbox One Elite Controller (Model 1698) Buttons Replacement: step 5, image 3 of 3
    • Flip the controller so that the buttons are face up to prevent the vibration motors from falling out of the controller.
    • Remove the D-pad by lifting the bottom and pulling it up.
    • Remove the entire plastic faceplate by pulling it up gently.
    • Remove the thumbsticks by pulling them off from the top.
  6. Xbox One Elite Controller (Model 1698) Buttons Replacement: step 6, image 1 of 2 Xbox One Elite Controller (Model 1698) Buttons Replacement: step 6, image 2 of 2
    • Remove the small black mode switch from the front of the controller.
    • The backplate gets a little stuck on the port at the bottom so you may have to use a prying motion to remove.
    • Be careful in the next step when pulling the main assembly apart from the backplate. There is a ribbon cable that connects the two parts that must stay in tact.
    • Remove the backplate from the main assembly by pulling them apart.
  7. Xbox One Elite Controller (Model 1698) Buttons Replacement: step 7, image 1 of 1
    Tool used on this step:
    Buy
    • The small ribbon cable connects the back cover to the internals of the controller. To remove the cable, lift the black lever on the opposite side of the connector from the cable.
    • Use tweezers to unplug the ribbon cable on the side closest to the back cover by pulling the cable parallel to the surface of the circuit board.
  8. Xbox One Elite Controller (Model 1698) Buttons Replacement: step 8, image 1 of 2 Xbox One Elite Controller (Model 1698) Buttons Replacement: step 8, image 2 of 2
    • Mark each motor according to where it attaches. The rumble motors are different so they will not work if you switch them.
    • Take note of where the red and black motor wires attach because they should be reattached in the same order.
    • Turn over the controller so that the thumbsticks are facing down.
    • Use tweezers and a soldering iron (Soldering Iron Guide) to remove the black and red wires from the motherboard.
    • This will release the rumble motor from the controller assembly.
  9. Xbox One Elite Controller (Model 1698) Buttons Replacement, Buttons: step 9, image 1 of 2 Xbox One Elite Controller (Model 1698) Buttons Replacement, Buttons: step 9, image 2 of 2
    • Use the T6 Torx screwdriver to remove the two T6 7mm screws located just above the rumble motor housing.
    • Be careful not to break the four wires that connect the motherboard to the buttons.
  10. Xbox One Elite Controller (Model 1698) Buttons Replacement: step 10, image 1 of 2 Xbox One Elite Controller (Model 1698) Buttons Replacement: step 10, image 2 of 2
    • Use the Soldering Iron Guide to help you with removing and attaching the wires.
    • Take note of where the grey and black motor wires attach because they should be reattached in the same order.
    • Use the soldering iron to desolder the four wires that connect the top and bottom mother board and remove them from the buttons.
  11. Xbox One Elite Controller (Model 1698) Buttons Replacement: step 11, image 1 of 2 Xbox One Elite Controller (Model 1698) Buttons Replacement: step 11, image 2 of 2
    • Be careful not to lose the small 9mm audio jack housing from under the main motherboard.
    • Remove the top motherboard by pulling it upwards.
    • Remove the small 9mm audio jack by gently lifting it from the motherboard.
  12. Xbox One Elite Controller (Model 1698) Buttons Replacement: step 12, image 1 of 2 Xbox One Elite Controller (Model 1698) Buttons Replacement: step 12, image 2 of 2
    • Use the T6 Torx Screwdriver to remove the four T6 7mm Torx screws, two screws for each trigger, from the trigger assembly.
    • Separate the plastic trigger piece from the spring mechanism by pulling the trigger piece up and the spring mechanism down.
  13. Xbox One Elite Controller (Model 1698) Buttons Replacement: step 13, image 1 of 3 Xbox One Elite Controller (Model 1698) Buttons Replacement: step 13, image 2 of 3 Xbox One Elite Controller (Model 1698) Buttons Replacement: step 13, image 3 of 3
    • Use the T6 Torx Screwdriver to unscrew the six T6 7mm Torx screws that hold the bottom motherboard to the plastic frame of the controller.
    • Use the plastic spudger to remove the silver assembly that holds the right and left bumpers, by lifting the plastic tab near the charging port of the Xbox.
    • Slowly remove the bottom motherboard by pulling it up and towards yourself.
  14. Xbox One Elite Controller (Model 1698) Buttons Replacement: step 14, image 1 of 2 Xbox One Elite Controller (Model 1698) Buttons Replacement: step 14, image 2 of 2
    • Remove the small green plastic piece by lifting it from the silicone holding it.
    • Remove the soft grey silicone piece that covers the buttons by pulling upwards on it.
  15. Xbox One Elite Controller (Model 1698) Buttons Replacement: step 15, image 1 of 2 Xbox One Elite Controller (Model 1698) Buttons Replacement: step 15, image 2 of 2
    • Remove each button by pulling each out one at a time. There should be seven buttons total.
    • Each button is keyed so it only fits in a specific way.
15 other people completed this guide.
Cara
1,543 Reputation
6 Guides authored
Cal Poly, Team S18-G4, Forte Fall 2017 Member of Cal Poly, Team S18-G4, Forte Fall 2017
CPSU-FORTE-F17S18G4
4 Members
24 Guides authored
One Comment
Thanks for the guide!
I found two little things that you could improve:
The green part on step 14 does not belong in this place. It is the pairing button. (I can send you a pictore of the correct placement)
The cable connectors are flip up / down ones. so you need to flip them up to reinsert them and they are much easier to remove if you flip them up.
rossi94 - Reply
Past 24 Hours: 4
Past 7 Days: 50
Past 30 Days: 199
All Time: 28,486
