Xbox One Wireless Controller Won’t Connect to Console
Arielle Sampson and 1 contributor
Last updated on
Does your Xbox One Wireless Controller refuse to connect to your Xbox console? Xbox One Wireless Controllers are susceptible to a range of problems that could cause them to stop connecting to Xbox consoles. Check the following possible causes to identify and solve the problem.
Causes
If your Xbox One Wireless Controller is not turning on, the controller might need to be charged. Plug the controller into the Xbox console using a USB cord. To check the controller’s battery level, press the Xbox button, and navigate to the home screen. The controller’s charge should be displayed in the bottom right corner of the home screen. Allow the controller to charge until the controller’s charge level is full (this could take several hours).
If your Xbox One Wireless Controller is losing battery power very quickly, the controller’s batteries may be faulty. If the batteries will not charge or lose charge very quickly, replace the batteries using the Xbox One Elite Wireless Controller Series 1 (Model 1698) Battery Replacement Guide.
2
If you have ensured that your Xbox One Wireless Controller is charged, a conflicting signal may be responsible for connectivity issues. Turn off nearby wireless devices and try reconnecting the controller.
3
If all nearby wireless devices are turned off and you are still experiencing connectivity issues, there may be too many controllers connected to your Xbox console. Make sure that you do not have more than eight controllers connected to the console at any one time (eight controllers is the limit for an Xbox One console).
4
If you set down your Xbox One Wireless Controller for longer than 15 minutes and come back to an unresponsive controller, the controller may need to be turned back on and reconnected.
5
If your Xbox One Wireless Controller is farther than 30 feet (9.1 meters) away from your Xbox console, the controller may not be able to detect the console. Move closer to the Xbox console and try to connect your controller, again.
6
If your Xbox One Wireless Controller has been synced to a different device, it will not automatically sync back to the Xbox console. Turn on your Xbox One console and hold down the “SYNC” button on your controller simultaneously with the “SYNC” button on your console. Hold these buttons down together until the light on your controller begins to flash rapidly, then release both “SYNC” buttons. After about five to ten seconds, your controller should connect to the console.
7
Some users have reported that their Xbox One Wireless Controller will not connect with their Xbox console when their headset microphone is plugged in. Unplug your headset’s microphone and reconnect the Xbox One Wireless Controller. If the controller does not connect automatically, sync the controller and console, again. Once a connection has been established, plug the microphone back into your headset.
If you are using a Model 1697 controller, your internal headphone jack may be damaged. Try unplugging the microphone and connect the controller, again. If you continue to have problems, try a different pair of headphones that are known to work.
View statistics:
Past 24 Hours:
12
Past 7 Days:
133
Past 30 Days:
566
All Time:
19,563
