Nintendo Switch Lite R button Replacement
  1. Nintendo Switch Lite R button Replacement, R button: step 1, image 1 of 1
    • Remove the four 6.3 mm long screws on the back using a Y1 tri-point screwdriver.
  2. Nintendo Switch Lite R button Replacement: step 2, image 1 of 1
    • Remove the two 3.6 mm long screws on the top using a Phillips #00 screwdriver.
  3. Nintendo Switch Lite R button Replacement: step 3, image 1 of 1
    • Remove the two 3.6 mm long screws on the bottom using a Phillips #00 screwdriver.
  4. Nintendo Switch Lite R button Replacement: step 4, image 1 of 1
    • Open up the device by inserting the opening tool into the speaker grille and twist the opening tool to open the device.
    • Twist the opening tool gently to avoid damaging any parts inside the device.
  5. Nintendo Switch Lite R button Replacement: step 5, image 1 of 1
    • Remove the two 4.5 mm long screws on the back of the ZR button using a Phillips #00 screwdriver.
  6. Nintendo Switch Lite R button Replacement: step 6, image 1 of 1
    • Carefully remove the R button.
  7. Nintendo Switch Lite R button Replacement: step 7, image 1 of 1
    • Use a napkin with rubbing alcohol to clean the area.
  8. Nintendo Switch Lite R button Replacement: step 8, image 1 of 1
    • Replace the old R button with a new R button carefully.
2 other people completed this guide.
Omar Hernandez
187 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 7
Past 7 Days: 48
Past 30 Days: 279
All Time: 1,456
