Retina MacBook 2015 Battery Replacement
  1. Retina MacBook 2015 Battery Replacement, Unfasten the lower case: step 1, image 1 of 1
    Tool used on this step:
    Magnetic Project Mat
    $19.95
    Buy
    • Before proceeding, unplug and power down your MacBook. Close the display and flip it upside-down.
    • Remove the following eight screws securing the lower case:
    • Two 1.8 mm P5 Pentalobe screws
    • Four 2.9 mm P5 Pentalobe screws
    • Two 6.1 mm P5 Pentalobe screws
    • Note the orientation of the screws as you remove them—they need to be reinstalled at a slight angle.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  2. Retina MacBook 2015 Battery Replacement: step 2, image 1 of 3 Retina MacBook 2015 Battery Replacement: step 2, image 2 of 3 Retina MacBook 2015 Battery Replacement: step 2, image 3 of 3
    • Wedge your fingers between the upper case and the lower case, starting from the rear of the MacBook between the hinges.
    • Lift the lower case only slightly to avoid damaging the cables that connect the lower case to the upper case.
    • Keeping a firm grip, lift steadily until the lower case separates slightly from the upper case.
    • You may experience a lot of resistance when lifting the lower case. If necessary, slide an opening pick or other ESD-safe pry tool down the side edges of the lower case to pop the two hidden retaining clips free.
    • During reassembly, to re-engage the clips, press firmly near both side edges of the lower case (near where the pick is inserted in the third image) until you hear the clips snap into place.
  3. Retina MacBook 2015 Battery Replacement: step 3, image 1 of 1
    • While holding the lower case in place, carefully flip the MacBook over so the Apple logo faces up.
  4. Retina MacBook 2015 Battery Replacement: step 4, image 1 of 2 Retina MacBook 2015 Battery Replacement: step 4, image 2 of 2
    • Lift the upper case and display together from the front edge and raise it to about a 45˚ angle.
    • It may be helpful to prop the MacBook open in this position for the next step.
  5. Retina MacBook 2015 Battery Replacement: step 5, image 1 of 3 Retina MacBook 2015 Battery Replacement: step 5, image 2 of 3 Retina MacBook 2015 Battery Replacement: step 5, image 3 of 3
    • Use the flat end of a spudger to press and hold the small gold 'battery disconnect' button.
    • If the power LED is lit up, continue holding the button until the LED goes dark, and then release. This may take up to 10 seconds.
    • If the LED does not light, release the button after 5-10 seconds. Press and hold it again for 5-10 seconds, and release. Finally, press and hold it a third time for 5-10 seconds, and release.
    • This step ensures the MacBook is fully powered down and safe to work on.
  6. Retina MacBook 2015 Battery Replacement: step 6, image 1 of 1
    • Close the MacBook and carefully flip it upside-down.
  7. Retina MacBook 2015 Battery Replacement: step 7, image 1 of 1
    • Lifting from the front edge, open the lower case to an angle of about 45°.
    • Take care not to damage the ribbon cables that still attach the lower case to the MacBook.
  8. Retina MacBook 2015 Battery Replacement: step 8, image 1 of 2 Retina MacBook 2015 Battery Replacement: step 8, image 2 of 2
    Buy
    • Use tweezers to peel back the tape covering the trackpad cable ZIF connector.
  9. Retina MacBook 2015 Battery Replacement: step 9, image 1 of 2 Retina MacBook 2015 Battery Replacement: step 9, image 2 of 2
    • Use a spudger to carefully flip up the retaining flap on the trackpad cable ZIF connector.
  10. Retina MacBook 2015 Battery Replacement: step 10, image 1 of 2 Retina MacBook 2015 Battery Replacement: step 10, image 2 of 2
    • Disconnect the trackpad ribbon cable from the trackpad by pulling it gently through its slot in the frame.
  11. Retina MacBook 2015 Battery Replacement: step 11, image 1 of 2 Retina MacBook 2015 Battery Replacement: step 11, image 2 of 2
    • Carefully turn the MacBook over, so that the lower case lays flat.
    • Raise the upper case/display assembly to about a 90° angle, and prop it up against something sturdy so you don't have to hold it.
    • Add a piece of tape near the track pad to secure the upper case and prevent accidental movement.
    • It's possible to open the MacBook all the way and lay both sides down flat, but this may damage the flex cables and is not recommended.
  12. Retina MacBook 2015 Battery Replacement: step 12, image 1 of 2 Retina MacBook 2015 Battery Replacement: step 12, image 2 of 2
    • Remove the single 2.9 mm T5 Torx screw securing the battery connector to the logic board.
    • 2015 models have a silver grounding clip with two foam pads directly under this screw, which may come loose. Be sure to reinstall it during reassembly.
  13. Retina MacBook 2015 Battery Replacement: step 13, image 1 of 2 Retina MacBook 2015 Battery Replacement: step 13, image 2 of 2
    Battery Blocker
    $3.99
    Buy
    • As an added precaution, you may physically disconnect the battery by inserting a battery isolation pick between the logic board and the battery connector.
  14. Retina MacBook 2015 Battery Replacement: step 14, image 1 of 1
    • Remove the two screws securing the USB-C port cable bracket:
    • 1.1 mm Tri-point Y00 screw
    • Some variations of this model may use a Phillips #00 screw.
    • 3.5 mm T5 Torx screw
  15. Retina MacBook 2015 Battery Replacement: step 15, image 1 of 2 Retina MacBook 2015 Battery Replacement: step 15, image 2 of 2
    • Use the flat end of a spudger to disconnect the USB-C port cable bracket by prying it straight up from the logic board.
    • To reconnect this cable, first line up the metal bracket over the screw holes, then press down on the middle of the bracket. Make sure it's aligned correctly, or you may damage the connector.
  16. Retina MacBook 2015 Battery Replacement: step 16, image 1 of 2 Retina MacBook 2015 Battery Replacement: step 16, image 2 of 2
    • Use a spudger to flip open the retaining flap on the audio jack board cable ZIF connector.
  17. Retina MacBook 2015 Battery Replacement: step 17, image 1 of 1
    • Disconnect the audio jack board ribbon cable by pulling it straight back out of the ZIF connector.
    • During reassembly, orient the ribbon cable so that the side with the white stripe faces you, as shown.
  18. Retina MacBook 2015 Battery Replacement, Retina MacBook 2015 Lower Case Assembly Removal: step 18, image 1 of 2 Retina MacBook 2015 Battery Replacement, Retina MacBook 2015 Lower Case Assembly Removal: step 18, image 2 of 2
    Buy
    • Use tweezers to peel back the tape covering the display cable connector.
  19. Retina MacBook 2015 Battery Replacement: step 19, image 1 of 2 Retina MacBook 2015 Battery Replacement: step 19, image 2 of 2
    • It's possible the metal retaining flap on the display cable connector may flip open, remaining stuck to the tape.
    • If so, use the flat end of a spudger to hold down the retaining flap while peeling the tape away with the tweezers.
  20. Retina MacBook 2015 Battery Replacement: step 20, image 1 of 1
    • Use the flat end of a spudger to flip open the retaining flap on the display cable connector.
    • Try to keep it clear of the tape, or it may re-adhere and make cable removal difficult.
  21. Retina MacBook 2015 Battery Replacement: step 21, image 1 of 3 Retina MacBook 2015 Battery Replacement: step 21, image 2 of 3 Retina MacBook 2015 Battery Replacement: step 21, image 3 of 3
    iOpener
    $12.99
    Buy
    • Carefully slide the flat end of a spudger underneath the display cable to separate the adhesive holding it to the lower case.
    • Take care not to damage the cable. If it doesn't separate easily, heat the cable and/or the case directly beneath it with a hair dryer or iOpener to soften the adhesive, and try again.
  22. Retina MacBook 2015 Battery Replacement: step 22, image 1 of 1
    • Disconnect the display cable by gently pulling it straight out of its connector.
    • Immediately close the retaining flap.
    • The flap must remain closed when the cable is reinserted during reassembly. Carefully line up the cable with the gold contacts facing down, and gently slide it into the connector. Take care not to crimp or damage the cable. When fully inserted, the indentations on the sides should not be visible.
  23. Retina MacBook 2015 Battery Replacement: step 23, image 1 of 1
    • Separate the upper case assembly from the lower case assembly.
  24. Retina MacBook 2015 Battery Replacement, Logic Board: step 24, image 1 of 3 Retina MacBook 2015 Battery Replacement, Logic Board: step 24, image 2 of 3 Retina MacBook 2015 Battery Replacement, Logic Board: step 24, image 3 of 3
    Buy
    • Use tweezers to peel up the tape covering the two ZIF connectors—one for the right speaker cable, and one for the audio jack board cable.
  25. Retina MacBook 2015 Battery Replacement: step 25, image 1 of 3 Retina MacBook 2015 Battery Replacement: step 25, image 2 of 3 Retina MacBook 2015 Battery Replacement: step 25, image 3 of 3
    • Use the point of a spudger to flip up both ZIF connector retaining flaps.
  26. Retina MacBook 2015 Battery Replacement: step 26, image 1 of 2 Retina MacBook 2015 Battery Replacement: step 26, image 2 of 2
    • Carefully pull straight back on the two pieces of tape you just peeled up to disconnect the two ribbon cables.
  27. Retina MacBook 2015 Battery Replacement: step 27, image 1 of 2 Retina MacBook 2015 Battery Replacement: step 27, image 2 of 2
    • Use the point of a spudger to peel up the foam pad covering the two antenna connectors.
  28. Retina MacBook 2015 Battery Replacement: step 28, image 1 of 3 Retina MacBook 2015 Battery Replacement: step 28, image 2 of 3 Retina MacBook 2015 Battery Replacement: step 28, image 3 of 3
    • Insert one arm of your angled tweezers under the metal neck of the first antenna connector and pry up to disconnect it.
    • The antenna connectors and sockets are extremely fragile. Be very careful to lift only on the connector, and not on the socket itself. Do not lift under the cable, or put any unnecessary strain on it.
  29. Retina MacBook 2015 Battery Replacement: step 29, image 1 of 3 Retina MacBook 2015 Battery Replacement: step 29, image 2 of 3 Retina MacBook 2015 Battery Replacement: step 29, image 3 of 3
    • Pry up the second antenna connector to disconnect it.
  30. Retina MacBook 2015 Battery Replacement: step 30, image 1 of 2 Retina MacBook 2015 Battery Replacement: step 30, image 2 of 2
    • Use a spudger to disconnect the left speaker cable connector by prying it straight up from the logic board.
  31. Retina MacBook 2015 Battery Replacement: step 31, image 1 of 2 Retina MacBook 2015 Battery Replacement: step 31, image 2 of 2
    • Use a spudger to flip up the retaining flap on the trackpad cable ZIF connector.
  32. Retina MacBook 2015 Battery Replacement: step 32, image 1 of 2 Retina MacBook 2015 Battery Replacement: step 32, image 2 of 2
    • Disconnect the trackpad cable from the logic board by gently pulling it straight out of its connector.
    • During reassembly, check that your ZIF connector flaps are flipped up before reinserting their cables.
  33. Retina MacBook 2015 Battery Replacement: step 33, image 1 of 1
    • Remove the single 3.5 mm T5 Torx screw securing the logic board to the lower case.
  34. Retina MacBook 2015 Battery Replacement: step 34, image 1 of 3 Retina MacBook 2015 Battery Replacement: step 34, image 2 of 3 Retina MacBook 2015 Battery Replacement: step 34, image 3 of 3
    • Flip up the front edge of the logic board.
    • Handle the logic board only by its edges.
    • Lift and detach the EMI tape securing the logic board to the lower case.
    • If the tape feels stuck, heat it with a hair dryer or iOpener to soften the adhesive.
    • Reattach the tape securely during reassembly.
  35. Retina MacBook 2015 Battery Replacement: step 35, image 1 of 1
    • Remove the logic board.
  36. Retina MacBook 2015 Battery Replacement, Battery: step 36, image 1 of 3 Retina MacBook 2015 Battery Replacement, Battery: step 36, image 2 of 3 Retina MacBook 2015 Battery Replacement, Battery: step 36, image 3 of 3
    • Lift the back edge of the lower case assembly and prop it up at an angle using a book or foam block.
    • In the following steps, you'll apply liquid adhesive remover along the edges of the battery cells. Keeping part of the MacBook elevated will help the adhesive remover flow underneath the battery.
    • You can reorient the MacBook as needed throughout this procedure, but try to prevent the adhesive remover from touching any components other than the battery and metal chassis.
    • If necessary, add a layer of aluminum foil underneath your MacBook to protect your workspace from wayward drops of adhesive remover.
  37. Retina MacBook 2015 Battery Replacement: step 37, image 1 of 2 Retina MacBook 2015 Battery Replacement: step 37, image 2 of 2
    • iFixit adhesive remover contains acetone, a mild skin and eye irritant.
    • Wear eye protection when handling and applying the adhesive remover. (Eye protection is included in your kit.)
    • Do not wear contact lenses without eye protection.
    • Protective gloves are also included in your kit. If you are concerned about skin irritation, put your gloves on now.
  38. Retina MacBook 2015 Battery Replacement: step 38, image 1 of 3 Retina MacBook 2015 Battery Replacement: step 38, image 2 of 3 Retina MacBook 2015 Battery Replacement: step 38, image 3 of 3
    • Pull off the black rubber stopper from your bottle of adhesive remover.
    • Twist to loosen or remove the bottle cap before you cut the applicator tip.
    • This unseals the bottle and allows the pressure to equalize before you cut the applicator tip. If you skip this step, the adhesive remover may spray out unexpectedly when the tip is cut.
    • Use scissors to cut off the sealed tip of the applicator.
    • Cutting close to the narrow tip will give you better control so you can apply the adhesive remover in small amounts.
    • Twist and close the bottle cap securely before you proceed further.
  39. Retina MacBook 2015 Battery Replacement: step 39, image 1 of 3 Retina MacBook 2015 Battery Replacement: step 39, image 2 of 3 Retina MacBook 2015 Battery Replacement: step 39, image 3 of 3
    • The adhesive securing the battery cells to the lower case is located in the areas marked in red.
    • You may use this step for reference when applying the adhesive remover in the following steps.
  40. Retina MacBook 2015 Battery Replacement: step 40, image 1 of 2 Retina MacBook 2015 Battery Replacement: step 40, image 2 of 2
    • Apply a few drops of adhesive remover along the top edge of the front right battery cell.
    • You don't need to use very much. The small bottle contains more than twice the amount of solvent needed to remove all six battery cells.
    • Wait 2-3 minutes for the liquid adhesive remover to penetrate underneath the battery cell before you proceed to the next step.
  41. Retina MacBook 2015 Battery Replacement: step 41, image 1 of 3 Retina MacBook 2015 Battery Replacement: step 41, image 2 of 3 Retina MacBook 2015 Battery Replacement: step 41, image 3 of 3
    Plastic Cards
    $2.99
    Buy
    • After 2-3 minutes, slide one corner of a plastic card underneath the battery cell.
    • This should require minimal force. If you have trouble, apply more adhesive remover along the other edges of the battery cell and give it 2-3 additional minutes to penetrate.
    • Try not to deform the battery. A damaged or punctured battery can leak dangerous chemicals and/or catch fire.
    • It may help to gently twist the card to open up a slight gap between the battery cell and the MacBook's case.
    • Slide the card farther underneath the battery cell to separate it from the adhesive securing it to the case.
  42. Retina MacBook 2015 Battery Replacement: step 42, image 1 of 2 Retina MacBook 2015 Battery Replacement: step 42, image 2 of 2
    • Lift the battery cell from the right edge to fully separate it from the adhesive, but don't try to remove it.
    • Leave the plastic card underneath the battery cell to prevent it from re-adhering as you proceed to the next step.
  43. Retina MacBook 2015 Battery Replacement: step 43, image 1 of 2 Retina MacBook 2015 Battery Replacement: step 43, image 2 of 2
    • Repeat the previous three steps to separate the front left battery cell.
  44. Retina MacBook 2015 Battery Replacement: step 44, image 1 of 3 Retina MacBook 2015 Battery Replacement: step 44, image 2 of 3 Retina MacBook 2015 Battery Replacement: step 44, image 3 of 3
    • Repeat the previous steps to separate the large battery cell on the left side of the MacBook.
  45. Retina MacBook 2015 Battery Replacement: step 45, image 1 of 2 Retina MacBook 2015 Battery Replacement: step 45, image 2 of 2
    • Repeat the previous steps to separate the large battery cell on the right side of the MacBook.
    • Be careful not to damage the audio jack flex cable, near the back edge of the battery cell.
  46. Retina MacBook 2015 Battery Replacement: step 46, image 1 of 3 Retina MacBook 2015 Battery Replacement: step 46, image 2 of 3 Retina MacBook 2015 Battery Replacement: step 46, image 3 of 3
    • Lay the lower case assembly down flat, and apply adhesive remover to the two middle battery cells—at each side, and along the front edge (opposite the logic board area).
  47. Retina MacBook 2015 Battery Replacement: step 47, image 1 of 1
    • Apply some additional adhesive remover down the middle between the two battery cells.
    • Wait 2-3 minutes for the adhesive remover to penetrate before you proceed.
  48. Retina MacBook 2015 Battery Replacement: step 48, image 1 of 3 Retina MacBook 2015 Battery Replacement: step 48, image 2 of 3 Retina MacBook 2015 Battery Replacement: step 48, image 3 of 3
    • Insert your plastic card under the front edge one of the battery cells and separate it carefully.
    • If you're having trouble getting the card underneath the battery cell, try working a piece of floss or wire underneath the battery cell and pull it side-to-side in a sawing motion to separate the adhesive.
  49. Retina MacBook 2015 Battery Replacement: step 49, image 1 of 1
    • Repeat the previous step to separate the final battery cell.
  50. Retina MacBook 2015 Battery Replacement: step 50, image 1 of 3 Retina MacBook 2015 Battery Replacement: step 50, image 2 of 3 Retina MacBook 2015 Battery Replacement: step 50, image 3 of 3
    Buy
    • Remove the battery by lifting it away from the speaker and logic board area.
    • Take care not to drag the battery over the lower case assembly, or you may damage the speakers or flex cables.
    • Before installing your new battery, remove all the remaining adhesive from the MacBook's case.
    • Peel off larger pieces of adhesive using tweezers or gloved fingers.
    • Scrape away any remaining adhesive with a plastic tool, and clean the underlying areas with adhesive remover or isopropyl alcohol. Wipe in one direction, not back and forth, until all the adhesive residue is gone.
    • This can take quite a bit of work, so be patient.
  51. Retina MacBook 2015 Battery Replacement: step 51, image 1 of 3 Retina MacBook 2015 Battery Replacement: step 51, image 2 of 3 Retina MacBook 2015 Battery Replacement: step 51, image 3 of 3
    Tesa 61395 Tape
    $10.99
    Buy
    • Test your new battery's fit and alignment carefully before installing it.
    • Unlike most laptop batteries, the MacBook's battery is precisely contoured to fit the "terraced" shape of the lower case. Each cell must be correctly positioned, or the MacBook may not close correctly and damage may result.
    • Your replacement battery may come affixed to a thick plastic top liner to help keep the individual cells in position as you install it. Don't remove this liner until after the battery is installed.
    • If your battery came with adhesive pre-installed on the bottom, peel away the bottom plastic liners to expose the adhesive. If your battery did not come with adhesive, apply a thin double-sided adhesive tape such as Tesa 61395 to the lower case in the areas marked in red.
    • Carefully position the battery and set it into place. Press and hold each cell firmly for 5-10 seconds to secure it to the lower case. Afterward, peel off the plastic top liner along with any foam padding.
For optimal performance, calibrate your newly installed battery after completing this guide.
To avoid logic board damage, before powering on your MacBook, connect it to low-voltage power using a 5-Watt iPhone charger and a USB-C to USB-A cable.
If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
113 other people completed this guide.
Jeff Suovanen
429,576 Reputation
259 Guides authored
iFixit Member of iFixit
Staff
137 Members
17,524 Guides authored
81 Comments
Beautiful. ‘Followed the instructions to a T. No issues at all. Thanks!
Peter Rasmussen - Reply
Everything worked, except the keyboard. No backlight, no power. Using remote keyboard for now. Any ideas? Trackpad works fine.
Neal Abrams - Reply
@nabrams1 Check both cables that connect to the trackpad—make sure all four connectors are clean and fully seated, and that the cables aren’t damaged in any way. The first cable connects the keyboard to the trackpad, and should not have been disconnected, but check it anyway. The second cable connects both keyboard + trackpad to the logic board. Good luck!
Jeff Suovanen -
I did try all of those and checked the cables and ZIF connectors under a microscope. I am thinking a bad trackpad now since it works fine, but the keyboard does not respond. The only way I have figured out o use the machine is to disconnect and reconnect the battery, which is not easy. Otherwise, I cannot power it on myself since the power button is part of the keyboard. Apple won’t touch this now since I replaced the battery myself, so it is kind of a brick. I can’t run AHT since the keyboard doesn’t respond (command-D). Any ideas?
Neal Abrams - Reply
Bad trackpad seems possible. If the keyboard was working before the repair, there may be damage to the trackpad or the logic board itself. It’s hard to say without swapping out parts to test, unless you have a microscope + multimeter + board schematic, and we’re rapidly getting out of DIY territory there. I’d probably take another look at the cables and sockets just to make extra sure it’s not something simple. Hope this helps!
Jeff Suovanen -
Past 24 Hours: 55
Past 7 Days: 376
Past 30 Days: 1,711
All Time: 180,852
