Samsung Chromebook 3 Speakers Replacement
  1. Samsung Chromebook 3 Speakers Replacement, Bottom Case: step 1, image 1 of 2 Samsung Chromebook 3 Speakers Replacement, Bottom Case: step 1, image 2 of 2
    • Place the Chromebook face down so that the bottom case is exposed.
    • Using a Phillips #00 screwdriver, remove nine 4.6mm screws from the back casing.
  2. Samsung Chromebook 3 Speakers Replacement: step 2, image 1 of 3 Samsung Chromebook 3 Speakers Replacement: step 2, image 2 of 3 Samsung Chromebook 3 Speakers Replacement: step 2, image 3 of 3
    • Use a iFixit opening tool to gently pry the case up from the vent on the hinge side of the Chromebook.
    • You should hear a popping sound as the connectors disengage inside the case.
  3. Samsung Chromebook 3 Speakers Replacement: step 3, image 1 of 1
    • Lift the case up and off the device
  4. Samsung Chromebook 3 Speakers Replacement, Speakers: step 4, image 1 of 2 Samsung Chromebook 3 Speakers Replacement, Speakers: step 4, image 2 of 2
    • Disconnect the battery from the motherboard by prying upwards on the cable connector with a spudger.
  5. Samsung Chromebook 3 Speakers Replacement: step 5, image 1 of 3 Samsung Chromebook 3 Speakers Replacement: step 5, image 2 of 3 Samsung Chromebook 3 Speakers Replacement: step 5, image 3 of 3
    • Remove one 4.9mm silver screw from each speaker with a Phillips #00 screwdriver.
  6. Samsung Chromebook 3 Speakers Replacement: step 6, image 1 of 3 Samsung Chromebook 3 Speakers Replacement: step 6, image 2 of 3 Samsung Chromebook 3 Speakers Replacement: step 6, image 3 of 3
    • Use a plastic spudger to gently coax the cable connecter sideways from the motherboard and the left speaker. When disconnected, remove speaker.
  7. Samsung Chromebook 3 Speakers Replacement: step 7, image 1 of 3 Samsung Chromebook 3 Speakers Replacement: step 7, image 2 of 3 Samsung Chromebook 3 Speakers Replacement: step 7, image 3 of 3
    • Use a plastic spudger to gently disconnect the cable connecter from the daughterboard and the right speaker. Remove the speaker.
Sarah Westberg
23,477 Reputation
70 Guides authored
iFixit Member of iFixit
Staff
139 Members
17,545 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 533
