iPhone XR LCD and Digitizer Replacement
  1. iPhone XR LCD and Digitizer Replacement, Remove the pentalobe screws: step 1, image 1 of 2 iPhone XR LCD and Digitizer Replacement, Remove the pentalobe screws: step 1, image 2 of 2
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 6.7 mm-long pentalobe screws at the bottom edge of the iPhone.
    • Opening the iPhone will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
    • There's a black rubber gasket just beneath the head on each pentalobe screw. For maximum protection against dust and liquid, check the condition of the gaskets or replace the screws during reassembly.
  2. iPhone XR LCD and Digitizer Replacement, Mark your opening picks: step 2, image 1 of 3 iPhone XR LCD and Digitizer Replacement, Mark your opening picks: step 2, image 2 of 3 iPhone XR LCD and Digitizer Replacement, Mark your opening picks: step 2, image 3 of 3
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
  3. iPhone XR LCD and Digitizer Replacement, Tape over any cracks: step 3, image 1 of 3 iPhone XR LCD and Digitizer Replacement, Tape over any cracks: step 3, image 2 of 3 iPhone XR LCD and Digitizer Replacement, Tape over any cracks: step 3, image 3 of 3
    • If your iPhone has a cracked screen, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
    • Lay overlapping strips of packing tape over the iPhone's display until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    • If the broken glass makes it difficult to get a suction cup to stick in the next few steps, try folding a strong piece of tape (such as duct tape) into a handle and lifting the display with that instead.
  4. iPhone XR LCD and Digitizer Replacement, Tape over any cracks: step 4, image 1 of 3 iPhone XR LCD and Digitizer Replacement, Tape over any cracks: step 4, image 2 of 3 iPhone XR LCD and Digitizer Replacement, Tape over any cracks: step 4, image 3 of 3
    • Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
    • If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
    • If all else fails, you can superglue the suction cup to the screen.
  5. iPhone XR LCD and Digitizer Replacement, Anti-Clamp instructions: step 5, image 1 of 3 iPhone XR LCD and Digitizer Replacement, Anti-Clamp instructions: step 5, image 2 of 3 iPhone XR LCD and Digitizer Replacement, Anti-Clamp instructions: step 5, image 3 of 3
    Tool used on this step:
    Anti-Clamp
    $24.95
    Buy
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  6. iPhone XR LCD and Digitizer Replacement: step 6, image 1 of 3 iPhone XR LCD and Digitizer Replacement: step 6, image 2 of 3 iPhone XR LCD and Digitizer Replacement: step 6, image 3 of 3
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  7. iPhone XR LCD and Digitizer Replacement: step 7, image 1 of 3 iPhone XR LCD and Digitizer Replacement: step 7, image 2 of 3 iPhone XR LCD and Digitizer Replacement: step 7, image 3 of 3
    • Heat an iOpener and thread it through the arms of the Anti-Clamp.
    • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the display and/or internal battery, so proceed with care.
    • Fold the iOpener so it lays on the bottom edge of the iPhone.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick under the screen and the plastic bezel, not the screen itself.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
  8. iPhone XR LCD and Digitizer Replacement, Heat up the screen: step 8, image 1 of 1
    • Heating the lower edge of the iPhone helps soften the adhesive securing the display, making it easier to open.
    • Use a hairdryer or heat gun, or prepare an iOpener and apply it to the lower edge of the iPhone for about a minute in order to soften up the adhesive underneath.
  9. iPhone XR LCD and Digitizer Replacement: step 9, image 1 of 2 iPhone XR LCD and Digitizer Replacement: step 9, image 2 of 2
    • If you're using a single suction handle, apply it to the bottom edge of the phone, while avoiding the curved portion of the glass.
  10. iPhone XR LCD and Digitizer Replacement, Lift the display slightly: step 10, image 1 of 3 iPhone XR LCD and Digitizer Replacement, Lift the display slightly: step 10, image 2 of 3 iPhone XR LCD and Digitizer Replacement, Lift the display slightly: step 10, image 3 of 3
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
    • The watertight adhesive holding the display in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
  11. iPhone XR LCD and Digitizer Replacement, Separate the screen adhesive: step 11, image 1 of 3 iPhone XR LCD and Digitizer Replacement, Separate the screen adhesive: step 11, image 2 of 3 iPhone XR LCD and Digitizer Replacement, Separate the screen adhesive: step 11, image 3 of 3
    • Slide the opening pick around the lower left corner and up the left edge of the iPhone, slicing through the adhesive holding the display in place.
    • Don't insert your pick more than 3 mm, as you may damage internal components.
  12. iPhone XR LCD and Digitizer Replacement, Screen information: step 12, image 1 of 1
    • There are delicate cables along the right edge of your iPhone. Don't insert your pick at the marked spots, as you may damage the cables.
  13. iPhone XR LCD and Digitizer Replacement: step 13, image 1 of 3 iPhone XR LCD and Digitizer Replacement: step 13, image 2 of 3 iPhone XR LCD and Digitizer Replacement: step 13, image 3 of 3
    • Re-insert your pick at the bottom edge of the iPhone, and slide it up the right side to continue separating the adhesive.
    • Don't insert your pick more than 3 mm, as you may damage the display cables.
  14. iPhone XR LCD and Digitizer Replacement: step 14, image 1 of 3 iPhone XR LCD and Digitizer Replacement: step 14, image 2 of 3 iPhone XR LCD and Digitizer Replacement: step 14, image 3 of 3
    • The top edge of the display is secured with both glue and clips.
    • Slide the opening pick around the top corner of the display, while gently pulling or wiggling the display down in the direction of the Lightning port.
    • The clips will break if you use too much force. Work carefully and be patient.
    • Don't insert your pick more than 3 mm, as you may damage the front panel sensor array.
    • Slide the pick to the opposite corner and cut any remaining adhesive securing the display.
  15. iPhone XR LCD and Digitizer Replacement: step 15, image 1 of 1
    • Pull on the small nub on the suction cup to remove it from the front panel.
  16. iPhone XR LCD and Digitizer Replacement, Open the iPhone: step 16, image 1 of 3 iPhone XR LCD and Digitizer Replacement, Open the iPhone: step 16, image 2 of 3 iPhone XR LCD and Digitizer Replacement, Open the iPhone: step 16, image 3 of 3
    • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
    • Lean the display against something to keep it propped up while you're working on the phone.
    • During reassembly, lay the display in position, align the clips along the top edge, and carefully press the top edge into place before snapping the rest of the display down. If it doesn't click easily into place, check the condition of the clips around the perimeter of the display and make sure they aren't bent.
  17. iPhone XR LCD and Digitizer Replacement, Unscrew the battery connector cover: step 17, image 1 of 2 iPhone XR LCD and Digitizer Replacement, Unscrew the battery connector cover: step 17, image 2 of 2
    Magnetic Project Mat
    $19.95
    Buy
    • Remove three 1.2 mm Y000 screws securing the battery connector cover bracket.
    • Remove the bracket.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your iPhone.
    • During reassembly, this is a good point to power on your iPhone and test all functions before you seal the display in place. Be sure to power your iPhone back down completely before you continue working.
  18. iPhone XR LCD and Digitizer Replacement, Disconnect the battery: step 18, image 1 of 2 iPhone XR LCD and Digitizer Replacement, Disconnect the battery: step 18, image 2 of 2
    • Use the point of a spudger to pry the battery connector straight up out of its socket.
    • Try not to damage the black silicone seal surrounding this and other board connections. These seals provide extra protection against water and dust intrusion.
    • Bend the connector slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
  19. iPhone XR LCD and Digitizer Replacement, Unscrew the display connector cover: step 19, image 1 of 2 iPhone XR LCD and Digitizer Replacement, Unscrew the display connector cover: step 19, image 2 of 2
    • Remove the two 1.2 mm Y000 screws securing the display connector bracket.
  20. iPhone XR LCD and Digitizer Replacement, Disconnect the digitizer: step 20, image 1 of 2 iPhone XR LCD and Digitizer Replacement, Disconnect the digitizer: step 20, image 2 of 2
    • Use the tip of a spudger to pry up and disconnect the digitizer cable.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
    • If any part of your screen doesn't respond to touch after your repair, disconnect the battery and then re-seat this connector, making sure it clicks fully into place and that there's no dust or other obstruction in the socket.
  21. iPhone XR LCD and Digitizer Replacement, Disconnect the display: step 21, image 1 of 2 iPhone XR LCD and Digitizer Replacement, Disconnect the display: step 21, image 2 of 2
    • Use the tip of a spudger to disconnect the display cable connector.
  22. iPhone XR LCD and Digitizer Replacement, Unscrew the logic board connector cover: step 22, image 1 of 2 iPhone XR LCD and Digitizer Replacement, Unscrew the logic board connector cover: step 22, image 2 of 2
    • Remove the five screws securing the logic board connector bracket to the rear case:
    • One 1.3 mm Phillips #000 screw
    • One 1.5 mm Phillips #000 screw
    • Three 1.2 mm Y000 screws
    • Be careful not to lose the smaller bracket clipped onto the edge. It's secured with a small clip and is easy to accidentally knock off of the larger bracket.
  23. iPhone XR LCD and Digitizer Replacement, Disconnect the front sensors: step 23, image 1 of 2 iPhone XR LCD and Digitizer Replacement, Disconnect the front sensors: step 23, image 2 of 2
    • Use the tip of a spudger to pry the front sensor assembly connector up from its socket.
  24. iPhone XR LCD and Digitizer Replacement, Remove the display assembly: step 24, image 1 of 1
  25. iPhone XR LCD and Digitizer Replacement, Unscrew the earpiece speaker: step 25, image 1 of 1
    • Remove the four screws securing the speaker/sensor assembly to the back of the display:
    • Two 1.6 mm Phillips screws
    • One 2.3 mm Phillips screw
    • One 1.2 mm Y000 screw
  26. iPhone XR LCD and Digitizer Replacement, Flip the speaker over: step 26, image 1 of 2 iPhone XR LCD and Digitizer Replacement, Flip the speaker over: step 26, image 2 of 2
    Buy
    • Using tweezers, gently flip the speaker assembly over—down and away from the top edge of the display.
    • The speaker remains attached via a very thin flex cable. Be careful not to strain or damage the cable.
  27. iPhone XR LCD and Digitizer Replacement, Heat the front sensor strip: step 27, image 1 of 1
    • Use a hairdryer, a heat gun, or a heated iOpener applied to the top front of the display for about a minute, in order to soften the adhesive securing the sensors.
  28. iPhone XR LCD and Digitizer Replacement, Pry up the microphone: step 28, image 1 of 3 iPhone XR LCD and Digitizer Replacement, Pry up the microphone: step 28, image 2 of 3 iPhone XR LCD and Digitizer Replacement, Pry up the microphone: step 28, image 3 of 3
    • Carefully slide the flat edge of a spudger underneath the flex cable below the microphone.
    • Twist gently to separate the microphone, while being careful not to strain or damage the flex cable.
    • If needed, use the point of the spudger to finish separating the microphone from its notch in the front panel. If the microphone remains difficult to separate, apply more heat.
  29. iPhone XR LCD and Digitizer Replacement, Pry up the proximity sensor: step 29, image 1 of 3 iPhone XR LCD and Digitizer Replacement, Pry up the proximity sensor: step 29, image 2 of 3 iPhone XR LCD and Digitizer Replacement, Pry up the proximity sensor: step 29, image 3 of 3
    • Working left to right, slide an opening pick beneath the flex cable and underneath the proximity sensor + flood illuminator module.
    • Gently wiggle and lift to separate the module from its notch in the front panel.
    • It's helpful to lift and hold the speaker out of the way for access. Just be careful not to pull on the thin flex cable while you work.
  30. iPhone XR LCD and Digitizer Replacement, Remove the ambient light sensor bracket: step 30, image 1 of 2 iPhone XR LCD and Digitizer Replacement, Remove the ambient light sensor bracket: step 30, image 2 of 2
    • Use tweezers to slide the small bracket straight up and off of the ambient light sensor.
  31. iPhone XR LCD and Digitizer Replacement, Lift the ambient light sensor: step 31, image 1 of 2 iPhone XR LCD and Digitizer Replacement, Lift the ambient light sensor: step 31, image 2 of 2
    • Use tweezers to wiggle the ambient light sensor and lift it from its notch in the display.
    • If the sensor does not wiggle free after a few seconds, apply more heat and try again.
    • The sensor remains attached to the rest of the sensor assembly via a very thin flex cable. Be careful not to strain or damage the cable.
  32. iPhone XR LCD and Digitizer Replacement: step 32, image 1 of 3 iPhone XR LCD and Digitizer Replacement: step 32, image 2 of 3 iPhone XR LCD and Digitizer Replacement: step 32, image 3 of 3
    • If you successfully removed the entire ambient light sensor, as shown in the first photo, continue to the next step below.
    • If the white diffuser strip is detached and remains embedded in the display, as shown in the second photo, you will need to carefully lever it out along the top edge using a thin blade or pry tool. Re-applying heat first may make this task a bit easier.
    • During reassembly, install the diffuser into the display first, making sure it faces the right direction (the front-facing side is shown in the first image, and the rear-facing side is shown in the third).
    • Then, set the ambient light sensor on top of the diffuser. You will need to hold the sensor in position while installing the screws securing the earpiece/sensor assembly. Once the screws are tightened, the sensor will stay in place and work normally.
  33. iPhone XR LCD and Digitizer Replacement, Remove the speaker + front sensors: step 33, image 1 of 3 iPhone XR LCD and Digitizer Replacement, Remove the speaker + front sensors: step 33, image 2 of 3 iPhone XR LCD and Digitizer Replacement, Remove the speaker + front sensors: step 33, image 3 of 3
    • Remove the earpiece speaker and front sensor assembly.
    • During reassembly, check the position of the black plastic module containing these components:
    • Proximity sensor
    • Flood illuminator
    • The module must be positioned so that these components are not obstructed by any adhesive.
  34. iPhone XR LCD and Digitizer Replacement, Unscrew the LCD shield plate: step 34, image 1 of 3 iPhone XR LCD and Digitizer Replacement, Unscrew the LCD shield plate: step 34, image 2 of 3 iPhone XR LCD and Digitizer Replacement, Unscrew the LCD shield plate: step 34, image 3 of 3
    • Use a Y000 driver to remove the 1.1 mm screws securing the LCD shield:
    • Three screws on the side nearest the display cables
    • Two more screws on the opposite side
    • Press your driver firmly into the screw while turning it. If needed, you can use your spudger to brace each screw from behind, in order to apply more pressure to the screws without bending the shield.
  35. iPhone XR LCD and Digitizer Replacement: step 35, image 1 of 2 iPhone XR LCD and Digitizer Replacement: step 35, image 2 of 2
    • Remove the remaining 1.1 mm Y000 screws from the top and bottom edges of the LCD shield:
    • Two screws near the camera cutouts
    • Two screws at the bottom corners
  36. iPhone XR LCD and Digitizer Replacement, Add a little heat: step 36, image 1 of 2 iPhone XR LCD and Digitizer Replacement, Add a little heat: step 36, image 2 of 2
    • Apply a little heat from an iOpener (or hair dryer / heat gun) to the back of the display, in order to soften the adhesive securing the display cables to the LCD shield.
  37. iPhone XR LCD and Digitizer Replacement, Unstick the display cables: step 37, image 1 of 2 iPhone XR LCD and Digitizer Replacement, Unstick the display cables: step 37, image 2 of 2
    • Insert an opening pick between the display cables and LCD shield.
    • Slide it toward the bottom edge of the display to begin separating the cables.
    • Stop when you reach the end of the first cable.
  38. iPhone XR LCD and Digitizer Replacement, Separate the two cables: step 38, image 1 of 3 iPhone XR LCD and Digitizer Replacement, Separate the two cables: step 38, image 2 of 3 iPhone XR LCD and Digitizer Replacement, Separate the two cables: step 38, image 3 of 3
    • Re-insert your opening pick, this time between the two cables.
    • Slide the pick to the bottom edge of the display to separate the cables from each other.
  39. iPhone XR LCD and Digitizer Replacement: step 39, image 1 of 2 iPhone XR LCD and Digitizer Replacement: step 39, image 2 of 2
    • Grab each cable near its 90° bend, and peel them apart.
  40. iPhone XR LCD and Digitizer Replacement: step 40, image 1 of 2 iPhone XR LCD and Digitizer Replacement: step 40, image 2 of 2
    • Peel the entire digitizer cable away from the LCD shield, and fold it aside.
  41. iPhone XR LCD and Digitizer Replacement, Lift the shield plate: step 41, image 1 of 2 iPhone XR LCD and Digitizer Replacement, Lift the shield plate: step 41, image 2 of 2
    • Insert an opening pick under the top edge of the LCD shield, and twist to separate it from the display.
  42. iPhone XR LCD and Digitizer Replacement: step 42, image 1 of 2 iPhone XR LCD and Digitizer Replacement: step 42, image 2 of 2
    • Grab the LCD shield by its top edge and swing it upward a few degrees.
    • Using your spudger, press gently on the lower part of the display cable, pushing it through the cutout in the LCD shield.
  43. iPhone XR LCD and Digitizer Replacement: step 43, image 1 of 3 iPhone XR LCD and Digitizer Replacement: step 43, image 2 of 3 iPhone XR LCD and Digitizer Replacement: step 43, image 3 of 3
    • Raise the top edge of the LCD shield a bit higher, and feed the rest of the display cable through the cutout in the shield.
  44. iPhone XR LCD and Digitizer Replacement, Separate the display cable: step 44, image 1 of 3 iPhone XR LCD and Digitizer Replacement, Separate the display cable: step 44, image 2 of 3 iPhone XR LCD and Digitizer Replacement, Separate the display cable: step 44, image 3 of 3
    • Raise the LCD shield up at a higher angle, until you can see the rest of the display cable stuck to the back.
    • Slide a spudger between the LCD shield and the display cable, and separate them completely.
  45. iPhone XR LCD and Digitizer Replacement, Check the EMI fingers: step 45, image 1 of 3 iPhone XR LCD and Digitizer Replacement, Check the EMI fingers: step 45, image 2 of 3 iPhone XR LCD and Digitizer Replacement, Check the EMI fingers: step 45, image 3 of 3
    • As you lift the LCD shield, note the metal prongs on the bottom edge.
    • During reassembly, make sure these prongs (a.k.a. EMI fingers) are correctly inserted into the LCD frame as shown.
  46. iPhone XR LCD and Digitizer Replacement, Remove the shield: step 46, image 1 of 1
    • Remove the LCD shield.
  47. iPhone XR LCD and Digitizer Replacement: step 47, image 1 of 1
    • Only the LCD and digitizer remains.
Repair didn’t go as planned? Try some basic troubleshooting, or search our Answers forum for help.
88 other people completed this guide.
Jeff Suovanen
429,009 Reputation
259 Guides authored
iFixit Member of iFixit
Staff
136 Members
17,430 Guides authored
15 Comments
So it’s like the X had a baby with an 8
James Heinrich - Reply
Hello everyone! Hoping I can get some feedbacks on a problem I’m having. I’m doing a screen replacement on an XR but the bottom half of the screen is unresponsive to touch. The replacement screen is from another XR with original Apple screen. When I put the replacement screen back, it works fine so it can’t be anything that’s damaged on the replacement screen. Also this replacement screen does the same thing to any iphone XR I put in so I know it means there’s no problems with the logic board. The replacement screen only works with its original but not on any other XR.
duc - Reply
i have same problem. Need Help
RNS -
Did you find a way Around this ??im experiencing the same thing
abooismail1234 -
What if I just needed to replace the front outer glass only, what steps are needed? Do you have to disassemble the phone?
Gene - Reply
Past 24 Hours: 24
Past 7 Days: 262
Past 30 Days: 1,234
All Time: 127,411
