This teardown is not a repair guide. To repair your Airvape Legacy Pro, use our service manual.
  1. Airvape Legacy Pro Teardown, Airvape Legacy Pro Teardown: step 1, image 1 of 1
    • Remove the top cloth material with heat
    • The tape that holds the fabric is no longer sticky after removal. But I found that heating it up again and reapplying the fabric works!
    • Remove four Phillips head screws
    • Use a spudger to lift off the plastic panel
  2. Airvape Legacy Pro Teardown, Angled look at PCB: step 2, image 1 of 1
    • Just another photo
  3. Airvape Legacy Pro Teardown, Under wireless charger: step 3, image 1 of 1
    • The wireless charging coil sits on a sticky pad, can be easily lifted with tweasers
ShellingRook27
1,790 Reputation
7 Guides authored
Repair For You Member of Repair For You
Business
1 Member
11 Guides authored
4 Comments
Looking forward to seeing this continue!
andypapster - Reply
nothing more with the teardown?
seedy53 - Reply
I think on FC he mentioned this was still his primary device and until he replaces it, he won’t do a further tear down.
andypapster -
Yeah, that is all for now. Like Andy said I'm still using this device and will do a full destructive teardown when I replace it. I'll update the introduction with that information.
ShellingRook27 -
Past 24 Hours: 3
Past 7 Days: 29
Past 30 Days: 178
All Time: 353
