Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
MacBook won't wake up from Hibernation
I have a MacBook that won't wake up from hibernation mode.
i wanted to drain the battery and let the MacBook go all the way down.
(i needed some voltage informations from the "empty" battery)
removed the battery, made my "stuff" and tried to start the MacBook again - but nothing - it stays dead, i charged the battery in another MacBook, put it in the dead one and nothing.
tried to start it with the powercord & the battery, only with the powercord - but still nothing.
tried it without the topcase (to rule a topcase problem out)
it does not react in any way.
changed the dc-in board - nothing.
one thing i noticed - the magsafe connector does not show anything when plugged to the MacBook (tried several ones) - BUT, when i plug in the magsafe and press the power button, the magsafe connector starts to flash orange (very faint)
any suggestions what in could try ?
Score -1
2 Comments
Is it hibernating or completely off?
by
now - completely off
by
Add a comment
Chosen Solution
As good a tech as you are, I'd start tracking it down with a voltmeter, starting at the mag port.
Score 2
3 Comments:
Agreed + Ralph
by
thanks for the tip, i'll try that later (it's 5am - so later will be better)
by
hi richard, i accepted your answer because it was the only way to start handling this issue
by
Add a comment
Try holding down the option key why you turn the power on. It should come up with which HD you want to boot from, may get you passed the hibernation mode.
Score 1
1 Comment:
nope - didn't change anything, still dead
by
Add a comment
here we go again - first of all i want to thank richard for his suggestion - i teared it apart and found something - i have no idea how it happened
i think the pictures are pretty revealing i will get tomorrow something to hold my tiny jeweler magnifier (picters were taken with it and my nokia phone ;-) ) - and then i try to fix it
Score 1
2 Comments:
We call that a toasted board ;-)
by
and i call that a challenge ;-)
by
Add a comment
markus have you tried reseting the SMU and PRAM? Ralph
http://support.apple.com/kb/HT3964
http://support.apple.com/kb/HT1379
Add a comment
Add your answer
markus weiher will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 2,958
