Buttons Don't Work on stick
When I pull the joystick to the left the buttons work just fine. But if i pull my joystick to the right the buttons on the stick stop working any idea?
Do the buttons on the base still work, independent of the joystick position?
Do the LEDs still light up even when the buttons stop working?
If both answers are "yes", it's probably a worn PWM signal cable between the joystick and the baseplate. I'd suggest replacing it with some slightly tougher wire. I've made a guide a while back on imgur, I'm afraid. But it should point you in the right direction. It assumes you know how to solder, though.
Long time since last response nut i went thru cables on my joystick and all seem to work and conections checked with multimeter. so any advice?
Mine seemed fine with a multimeter when disassembled, but probably had some damage around the hinge. It fixed itself when I replaced the cable.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 16
All Time: 1,877
