Repair guides and support for the first generation Nissan Murano, from the 2003 model year to 2007.
19 Questions View all
Why does my check oil light go on & off?
When accelerating at slow speeds, I hear a clicking sound coming from under the hood. When I take my foot off the gas, the clicking sound ends and my check oil light goes on and off. It really doesnt follow any particular pattern.
Add a comment
1 Answer
Most Helpful Answer
@canderson68 make sure that you do have enough oil in your engine and change your oilfilter as well as your oil. It is possible that you have a bad pressure switch but start with the easy things first. The clicking sound could come from your lifters and the light comes on because your pump cannot pump any more oil because there might not be enough or a clogged filter that does not let it pass back into the pan quickly
Score 1
Add a comment
Add your answer
Carl Anderson will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 11
All Time: 131
