Mixing Paddle won't turn
Mixing Paddle does not turn whether in machine or out. Motor and pedestal for paddle work without pan but will not work in pan.
I had a similar problem, you need to perform the steps to replace the shaft seal then clean and lubricate the shaft. It may take a lot of force to remove the shaft. I used a dead blow rubber hammer and a drift to drive mine out. You need to be careful not to damage the shaft or bearing in the bread pan while driving the shaft out. As far as lube I used 3 in one oil but I’ll probably re-lube with silicone plumbers grease.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 10
All Time: 1,174
