Released on July 28th, 2017, the New Nintendo 2DS XL is a handheld gaming console succeeding the Nintendo 2DS.
206 Questions View all
My device doesn't start...
I’ve repaired the Nintendo 2ds xl top screen, because it was damaged.
Now if i want to turn on my device, the blue light turns on for about 4 seconds, both of the displays are flashing and then the blue light and both of the screens turns off :(
What can be the reason?
I’ve thought it can be the battery, changed it and the same issue is happening..
Score 1
Add a comment
1 Answer
Most Helpful Answer
Hi!
Check the ribbon cable connection of the displays. If those are not seated properly or if the cables themselves are a bit damaged (scuffed or dented), the console won't turn on.
Score 2
4 Comments:
But if the ribbon cable connection of the displays are not seated proberly, will both displays flash up then?
by
Hi!
Yes, a bad connection does not mean that there isn't any connection, it just means that it's not enough to get a good enough signal trough.
It's honestly a dumb feature implemented by Nintendo to have the consoles check the hardware upon boot and shutdown if anything is wrong.
by
can it also be a broken mainboard?
A shot smd or similar?
Or is it a pretty clear sign of no good connection?
by
To me it's a pretty clear sign of a bad connection. The chances that you broke the main board while replacing the display are quite low.
by
Add a comment
Add your answer
Michael D will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 14
All Time: 335
