A home electrical installation is a complex system of electrical components that bring power into a home and distribute it to the various outlets, appliances, and lighting fixtures.
24 Questions View all
Electric fan motor makes loud noise when turned on & jams
My electric fan will make a loud noise and the shaft will be hard to turn but will be easy to turn when its off
Its been lubricated, the cables are all connected too
1 Comment:
Does the fan have a capacitor? Is it good?
by
Add a comment
1 Answer
Hi
I suggest you to re-connect all the screws and if you already did then loosen the screws a little.
If everything is right in terms of mechanical then it would be short inside the motor
Add a comment
Add your answer
Blaze will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 20
All Time: 170
