Repair and disassembly guides for electronic keyboards.
214 Questions View all
Keyboard buttons won't work
Yamaha psr-82 My keyboards buttons from overall controls, accompaniment control, voice/style, sustain, auto harmony, chord memory, and song book. The only button that works is the power button. The adapter works and the keyboard keys work but everything else isn't.
Score 2
Add a comment
1 Answer
Most Helpful Answer
Hi
I don’t usually work in Yamahas but I have worked on lots of Roland machines and when the controls and button stop working but the keys work that tends to mean that the daughter board on the top half of the keyboard has a issue
I can’t say exactly what the issue is as it can’t vary from machine to machine but it should be obvious(I would look for blown components damage and corrosion),if you can’t see anything on the boards you can use this guide(linked below)if you would like:-)
Adding images to an existing question
Hopefully this helps
Any questions please ask
Score 1
2 Comments:
Hi @hellomacos,
It could also be something as simple as a loose cable connection to the board (at either end)
Cheers
by
Hi @jayeff
It could be that:-),it could also be a battery leak if it uses them
by
Add a comment
Add your answer
Adrianna Overfield will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 6
Past 30 Days: 19
All Time: 58
