A general-purpose audio device that transmits low audio frequencies to your ears.
22 Questions View all
Sparks forming inside subwoofer when plugged in .now it's not turning
When I plugged my subwoofers on . I saw sparks and crackling noise inside the subwoofer through the air out hole . And now it's not turning on . I don't know what to do . Somebody please help. I tried different sockets . But no use
Score 2
1 Comment
Hi
Is the sparks coming from the subwoofer itself or is it coming from a driver board inside the case?
by
Add a comment
1 Answer
Most Helpful Answer
@androtechm33260 sounds like you are having a power supply in your subwoofer that had a catastrophic failure. you have not told us the make and model of the subwoofer. At this point, the only thing you can do is to unplug it, stop trying to use ist and disassemble it. Lets see which components when up in smoke. I would thing by sparks etc. that this is an MOSFET or the Bridge Rectifier, but it is all a guess until we can see what happened. Post as many pictures as needed, to show your boards etc. Those pictures have to be large and clear so we can at least try and help you to fix your subwoofer.
Adding images to an existing question
Score 1
Add a comment
Add your answer
adwaithabhirami59 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 20
All Time: 84
