Repair and disassembly guides for Blu-Ray Players made by Panasonic.
5 Questions View all
Won't play Blu Ray disks anymore, only DVDs
My Blu-ray player will no longer play Blu-ray discs.  It tries to read it, and then just stops and this message appears on the screen:  "Cannot Read, please check the disk".  But, It plays DVDs just fine -- no problem at all.  I have tried older Blu-rays from as far back as 2007.  Today, I even opened a brand new Blu-ray disk -- never played before. And the same thing happened.  Could there be something wrong with whatever technology is specific to playing Blu-ray disks?
Update (10/18/23)
BTW - my player is the DMP-BD85, not 89, but I didn't see that listed on this site.
Score 2
Add a comment
Most Helpful Answer
Hi Cynthia,
You're most likely on the right track. Blu-Ray disks and DVD disks use completely different kinds of lasers when reading the disk; the DVD uses a red laser and the Blu-Ray uses a blue (well, technically violet) laser with a lower frequency allowing for smaller dots and thus more data to be packed into the same space.
So yes, it's entirely possible that your blue laser has failed but the red one is still working. They are almost always mounted on the same head so you may have to replace both at the same time. Start out with some basic troubleshooting as follows.
Optical Disc Drive (Blu-ray, DVD, CD) Troubleshooting - iFixit
Go through some of those suggestions and let us know what you find.
Score 3
3 Comments:
Jerry, I tried everything in the Troubleshooting guide you recommended here. I was able to easily move the laser assembly back and forth. I even powered it on and off a few times, so that I could see the lasers turning on, which they both did. I could definitely see the blue/violet light on the smaller lens. Regardless, I also went ahead and cleaned both lens with alcohol. I put the lid back on the disk drive cabinet, and tried playing both a Blu Ray and a DVD. Unfortunately the DVD played just fine, but the Blu ray did not. So, could the blu ray laser still be failed, even though I can see the Blue/violet light when its coming on?
by
The laser that reads the disk consists of two parts; you have the laser itself that generates the light then you have the optical pickup, which receives the light. Given that you've verified you're getting laser output, that pretty much leaves the optical pickup as the most likely source of the problem.
At this point I'd suggest you head on down to @oldturkey03's answer and look at running the self diagnostics and see if they offer any further clues.
He's also got the information on how to replace the optical pickup and the part number you'd need.
by
I ran the self-diagnostics, and it came up with code F00, which means: No error information. I don't see where in @oldTurkey03's answer that there is information about how to replace the optical pickup and the part number
by
Add a comment
@cynthianay26427 could also be that you have a dirty lens. Sometimes just running a commercially available lens cleaner will work. You can pick those up pretty much anywhere (even places like Walmart have those) If that does not work, and hopefully you have the remote for your BR player, you could run the self diagnostics and see what it tells you.
If you find that this is an issue with the BR then it is most likely the optical pickup unit or a dirty lens. Use the SM Panasonic DMP BD85 to work on your drive. It shows you how to disassemble it from the chassis and page #35 how to clean the lens. To work on it is not as complicated as it seems, just stay organized, keep the parts well labelled and separated and make sure no animal can mess with those (my cat is a pain;-)
While you work on your BR player, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. Yes there are a few guides for this device, but we can always use more of the in depth guides. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
"from as far back as 2007" I remember it like it was yesterday :-)
Repair is War on Entropy!
Score 3
5 Comments:
The diagnostics thing didn't work. The choice (80 SRV) didn't come up. Possibly this is different in the DMP-BD85, which is my model number.
See reply I made to Jerry
by
@cynthianay26427 I edited my answer to reflect the change in model number :-)
by
I ran the self-diagnostics, and it came up with code F00, which means: No error information. I don't see where there is information about how to replace the optical pickup and the part number as is suggested by @dadibrokeit
by
Hey @oldturkey03 do you have any further guidance for me?
by
Never mind. I found a used player on Ebay for less than the cost of a new optical pickup.
by
Add a comment
I would start with checking for any firmware updates. Page 14 of the owners manual has instructions on how to do that. There's also a troubleshooting guide in there, starting on page 30.
Have you looked inside at the actual lens to make sure it's not damaged?
Score 1
1 Comment:
The first thing I did was contact Panasonic support. They also directed me to check for a firmware update, which I did and my player is up-to-date on firmware. They also said to do a factory reset, which I did too. And it didn't fix the problem.
by
Add a comment
If it's a new disk in an old player it usually means your firmware no longer supports current encoding and needs updating. Unfortunately once the manufacturer stops supporting your model this becomes impossible, leaving you with no option by the buy a new machine.
1 Comment:
Although this may be somewhat interesting information, it's not relevant to this particular case since one of the first things Cynthia did was to try a wide variety of disks, including old ones and a brand new one.
The last thing I want to do is to discourage you from helping out, but please read the question and answers carefully before you answer.
by
Add a comment
Add your answer
Cynthia Naylor Smyth will be eternally grateful.
Past 24 Hours: 17
Past 7 Days: 128
Past 30 Days: 590
All Time: 3,012
