Ear Tips
8 Answers 16 Score |
Airpod Pro Left Earbud Not Connecting to Charging Case |
5 Answers 3 Score |
Pair button doesn't work |
2 Answers 1 Score |
Why are my airpods pro have a buzzing sound |
3 Answers 1 Score |
Airpod Earpiece Plastic falling off the rubber. |
Parts
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background
The Apple AirPods Pro were announced and released in October 2019 as a premium version of Apple’s popular AirPods. The AirPods Pro feature active noise cancellation, adaptive EQ, Transparency mode, and an IPX4 rating. They also have a shorter stem than the original AirPods and include silicone earphone tips.
The AirPods Pro range from $65–270 USD.
Identification
The AirPods Pro can be primarily identified by its model numbers: A2084 for the left earbud, A2083 for the right earbud, and A2190 for the charging case. You can find the charging case's model number printed on the underside of its lid. You can find your earbuds' model numbers by using your iPhone to go to Settings—Bluetooth and tapping the More info button next to your registered AirPods.
Technical Specifications
Processor: H1-based SiP
- Microphones:
- Dual Beamforming
- Single Inward-Facing
- Sensors:
- Dual Optical Sensors
- Motion-Detecting Accelerometer
- Speech-Detecting Accelerometer
- Force Sensor
- Audio Technology:
- Active Noise Cancellation
- Transparency mode
- Adaptive EQ
- Vent for pressure equalization
- Custom high-excursion Apple driver
- Custom high dynamic range amp
- Connectivity:
- Bluetooth 5.0
- Charging via Lightning or Qi-certified charger
- Dimensions:
- AirPods Pro: 1.22 x 0.86 x 0.94 in (30.9 x 21.8 x 24 mm)
- Case: 1.78 x 2.39 x 0.85 in (45.2 x 60.6 x 21.7 mm)
- Weight:
- AirPods Pro: 0.19 oz (5.4 g)
- Case: 1.61 oz (45.6 g)
