Regulator spring
1 Answer 0 Score |
extremely slow to build pressure |
9 Answers 5 Score |
Pump needs a new valve. |
1 Answer 0 Score |
Removing the shroud from a Craftsmam Model 919.166440 air compressor |
1 Answer 1 Score |
Air station quit working |
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background and Identification
An air compressor is a pneumatic device that converts power (using an electric motor, diesel or gasoline engine, etc.) into potential energy stored in pressurized air (i.e., compressed air). By one of several methods, an air compressor forces more and more air into a storage tank, increasing the pressure. When the tank's pressure reaches its engineered upper limit, the air compressor shuts off. The compressed air, then, is held in the tank until called into use.
The energy contained in the compressed air can be used for a variety of applications, utilizing the kinetic energy of the air as it is released and the tank depressurizes. When tank pressure reaches its lower limit, the air compressor turns on again and re-pressurizes the tank. An air compressor must be differentiated from a pump because it works for any gas/air, while pumps work on a liquid.
