Direction Pad
2 Answers 1 Score |
Can the Backbone One be modded for an iPad mini? |
1 Answer 0 Score |
My right thumb stick came off. Where can I get a new one? |
1 Answer 0 Score |
Backbone one ribbon cable is damaged. How can I replace it. |
2 Answers 0 Score |
Is there a replacement shell for the Backbone One 2nd Gen? |
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Specifications
Model: Backbone One
Release date: October 2020
Dimensions and Weight: 176.2 × 257.6 × 32.6mm (6.94 × 10.14 × 1.28in), 138 g (4.87 oz)
System requirements: iPhone with iOS 13 or later
- iPhone models: iPhone 12 Pro, iPhone 12 Pro Max, iPhone 12 mini, iPhone 12, iPhone 11 Pro, iPhone 11 Pro Max, iPhone 11, iPhone SE (1st Generation), iPhone SE (2nd Generation), iPhone XS, iPhone XS Max, iPhone XR, iPhone X, iPhone 8, iPhone 8 Plus, iPhone 7, iPhone 7 Plus, iPhone 6s, iPhone 6s Plus
Game recording: up to 1080p at 30fps with a 20mbps bitrate on latest iOS devices
Battery: no battery, Backbone One uses power from the iPhone, lightning port for pass-through charging the iPhone
3.5mm headphone jack: yes
Latency controls: ultra-low latency, clickable thumbsticks, hall-effect sensor-based analog triggers
