Armature
1 Answer 0 Score |
Will somewhat run if the brush caps are squeezed together, how to fix? |
1 Answer 0 Score |
Dremel 3000 will only work when pressing side lid |
1 Answer 5 Score |
Why is my Device not turning on? |
1 Answer 2 Score |
Why is my device running at inconsistent speeds? |
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background
The Dremel MultiPro 395 is a rotary tool manufactured by the Dremel company. The MultiPro 395 has a speed between 5,000-35,000rpm, which is displayed on the label on the front. The MultiPro came with a comfort grip and was double insulated to eliminate the need for grounding. The MultiPro initially sold for $96.89 and weighs about 2 pounds. The MultiPro was later replaced by the Dremel 3000 a few years later and was retired by the Dremel company.
Identification
The MultiPro is easily identified by the label on the front which says Dremel MultiPro, the model number and the speed at which it runs. The MultiPro can also be identified by the blue caps on either side of the MultiPro as well as the blue variable speed switch.
