2 Answers 0 Score |
Fridge not cooling, freezer is really cold |
1 Answer 0 Score |
Water dispenser leaks about 30 seconds into use |
Background
The GE GFE26JSM is a refrigerator from GE Appliances, a Haier company. This model is a bottom-mounted freezer style with French door access. It was added to the market in 2018 and falls under the category of built-in and compact refrigerators. The GFE26JSM model includes an automatic ice maker and a through-the-door service feature. It also has an anti-sweat heater switch and uses R-410A refrigerant, which does not deplete the ozone layer.
The GE GFE26JSM has a fresh food volume of 17.4 cu ft and a freezer volume of 8.2 cu ft, totaling 25.6 cu ft. The adjusted volume is 31.9 cu ft. The dimensions are 70 inches in height, 36 inches in width, and 34 inches in depth. The annual energy use is 700.0 kWh/year, which is below the US federal standard of 770.0 kWh/year.
Technical Specifications
- Manufacturer: GE Appliances, a Haier company
- Brand Name: GE
- Model Number: GFE26JSM****
- Refrigerator Style: Bottom-Mounted Freezer
- Defrost Type: Automatic
- Type: Refrigerator
- Refrigerator Access: French Door
- Built-in: Yes
- Compact: Yes
- Automatic Ice Maker: Yes
- Thru the Door Service: Yes
- Anti-Sweat Heater Switch: Yes
- Refrigerant Type: R-410A (Non-Ozone Depleting)
- Insulation Type: Non-Ozone-Depleting
- Fresh Food Volume (cu ft): 17.4
- Freezer Volume (cu ft): 8.2
- Total Volume (cu ft): 25.6
- Adjusted Volume (cu ft): 31.9
- Height (inches): 70
- Width (inches): 36
- Depth (inches): 34
- Annual Energy Use (kWh/year): 700.0
- US Federal Standard (kWh/year): 770.0
- Date Added: 2018
- Source: California Energy Commission
