Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Models
GTS22KHPARBB, GTS22KHPARCC, GTS22KHPARWW, GTS22KHPBRBB, GTS22KHPBRCC, GTS22KHPBRWW, GTS22KHPDRBB, GTS22KHPDRCC, GTS22KHPDRWW
Background
The GTS22KHP is a refrigerator model manufactured by GE Appliances. This model is designed with a top freezer style and does not include ice through the door. The refrigerator defrost system is automatic, indicating that it is designed to remove frost build-up without manual intervention. It uses a refrigerant type R-410A, which is non-ozone depleting and aligns with the refrigerator's insulation type that is also non-ozone-depleting.
The refrigerator's volume is divided between the fresh food storage and the freezer. The fresh food compartment has a volume of 15.4 cu ft, while the freezer has a volume of 6.3 cu ft, with a total volume of 21.7 cu ft. The device measures 67 inches in height, 33 inches in width, and 32 inches in depth. Annually, it uses around 527.0 kWh per year, just under the US Federal Standard of 529.0 kWh per year. The model was added to the product line in 2009.
Technical Specifications
- Manufacturer: GE Appliances, a Haier company
- Brand Name: General Electric
- Model Number: GTS22KHP****
- Refrigerator Style: Top Freezer w/o Ice thru-door
- Defrost Type: Automatic
- Type: Refrigerator
- Refrigerator Access: Door
- Anti-Sweat Heater Switch: Yes
- Refrigerant Type: R-410A (Non-Ozone Depleting)
- Insulation Type: Non-Ozone-Depleting
- Fresh Food Volume (cu ft): 15.4
- Freezer Volume (cu ft): 6.3
- Total Volume (cu ft): 21.7
- Height (inches): 67
- Width (inches): 33
- Depth (inches): 32
- Annual Energy Use (kWh/year): 527.0
- US Federal Standard (kWh/year): 529.0
- Date Added: 2009
- Source: California Energy Commission
