How to fix a clogged garbage disposal
2 Answers 1 Score |
Kenmore garbage disposal - No sound, just won't turn on |
2 Answers 0 Score |
How to replace the splash guard |
1 Answer 0 Score |
Badger 5 insinkerator: Why is the air gap still squirting out water? |
1 Answer 1 Score |
Kenmore garbage disposal is frozen how do I unfreeze it. |
Parts
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Models
AFC111V, GFB1050-01, GFB1050-02, GFB105001, GFB1050G01, GFB1050G02, GFB1050G03, GFB1050V-01, GFB1050V01, GFB1051-01, GFB1051-02, GFB1051G01, GFB1051G02, GFB1060F-01, GFB760F-01, GFB760H-01, GFB760V, GFB762F-00, GFB762F00, GFC1000-01 Show 51 more
GFC1000-02, GFC100001, GFC1000G01, GFC1000G02, GFC1000G03, GFC1001F-01, GFC1001F01, GFC1001VSS, GFC1020F-01, GFC1020F01, GFC1020T, GFC1020V, GFC1022F-00, GFC195-01, GFC195-02, GFC19501, GFC197-01, GFC197PG02, GFC20002, GFC22202, GFC24001, GFC240G01, GFC320F01, GFC320T, GFC320V, GFC325F-01, GFC325F01, GFC325T, GFC325V, GFC40002, GFC41002, GFC44001, GFC501F01, GFC501VSS, GFC520F01, GFC520T, GFC520V, GFC525F01, GFC525T, GFC525V, GFC530F01, GFC530T, GFC530V, GFC535V, GFC61001, GFC701VSS, GFC720T, GFC720V, GFC722F01, GFC900, GFC90001
Background
An in-sink unit for the disposal of food waste, also known as a waste disposal unit or a garburator. Designed to grind and shred food waste into small particles, allowing them to be washed down the drain along with water.
Theory of Operation
When the food is placed into the hopper and the disposer is running, the centrifugal force throws the food waste outward against the cutting edges of the shredder ring. The pivoting impeller arms, attached to the flywheel, push the food waste around and into the teeth of the shredder ring. As the food waste is pushed against and cut by the shredder ring, water running into the hopper flushes the ground food waste between the flywheel and the shredder ring, washing it into the drain housing assembly, where it is expelled into the drain.
Identification
A garbage disposal is a cylindrical-shaped device, typically made of metal or hard plastic.
The top of the garbage disposal is connected to the sink's drain while the side or bottom of the unit connects to the drainpipe. On the bottom or side of the unit, there may be a reset button used to reset the motor if it overheats or is stuck. Some models also have a hex key slot (Allen wrench slot) at the bottom center, which is used to manually rotate the motor to free a jam.
When installed under the sink, the garbage disposal connects to an electrical outlet with a power cord, or it may be hardwired into the electrical system.
Types
- Continuous Feed Disposers: A continuous feed disposer requires an on-off electrical switch that is remote from the disposer. Before food is placed into the hopper, the user must turn on the cold water faucet and turn on the electrical switch. Then the food waste is placed into the hopper. The food waste will be ground up and expelled into the drain.
- Batch Feed Disposers: In a batch feed disposer, the on-off operation of the disposer is controlled by the stopper. The on-off switch is built into the hopper. The stopper is the component that completes the circuit that allows the disposer motor to run. The hopper will hold the food waste until the user is ready to dispose of it. The food waste will be ground up and expelled into the drain.
Safety
Safety First! Before you begin any repair, remember that safety is paramount. Always disconnect your garbage disposal from the power source before attempting any repairs or diagnostics. This precaution is crucial to prevent electric shock or damage to your appliance as well as personal injury. These precautions should also be followed:
- Do not put your fingers or hands into the garbage disposer.
- When removing foreign objects, always use a long-handled pair of tongs or pliers.
- To reduce the risk of flying debris that can be expelled by the disposer, always be sure that the splash guard is properly installed.
- When replacing the garbage disposer, always be sure that it is properly grounded.
- Before attempting to free a jam in the garbage disposer, always disconnect the electric supply to the disposer.
