Rear Case
1 Answer 1 Score |
Why is my tv keeping restarting itself every 5 seconds with no picture |
1 Answer 0 Score |
Tv has white lines |
1 Answer 0 Score |
Metal prong broke off in video slot, how do I remove it |
1 Answer 1 Score |
Internal damage to screen? |
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background and Identification
The Samsung LN-T5265F is a 52-inch (diagonally) flat-panel HDTV. It features a resolution of 1920 by 1080 pixels, which is approximately double the pixel count of the typical 50-inch plasma television.
The LN-T5265F includes tuners for receiving analog and digital over-the-air broadcasts, but antennas are required for these functions. Cable television subscribers can use the TV’s built-in “QAM” tuner to find unscrambled cable channels without a set-top box. The television includes three HDMI inputs and two component videos. Users can add multiple high-definition video sources like satellite tuners or video game consoles. The LN-T5265F includes “CEC” control capability, which allows users to control other compatible HDMI-connected components using the television’s remote controller. The TV includes two 10-Watt built-in side-mounted stereo speakers. A USB port for digital photo/MP3 playback is located on the side of the LN-T5265F model.
The LN-T5265F television features an 8-millisecond pixel response time and an LCD (liquid crystal display) with a semi-gloss screen. It also includes a wide-range fluorescent backlight for extended color range. The LN-T5265F comes with a detachable swivel stand but is also wall-mountable, though the wall-mounting bracket is not included. It includes the name “Samsung” printed in capital letters in the center of the television’s bottom bezel.
Technical Specifications
Remote Control:
- Type: universal remote control
- Supported Devices: DVD player, VCR, cable box, satellite TV system
- Remote Control Technology: infrared
- Second remote control type: none
Video:
- Technology: TFT active matrix
- Widescreen: widescreen
- Widescreen Modes: 16:9, Conventional 4:3, Just, Wide, Zoom
- Color Temperature Control: Yes (Warm1/Warm2/Normal/Cool1/Cool2)
Connections:
- Type: HDMI, S-Video input, USB, VGA input, audio line-in, audio line-out, component video input, composite video/audio input, digital audio output (optical), headphones
- Connector Type: 15 pin HD D-Sub (HD-15), 19 pin HDMI Type A, 4 pin USB Type A, 4 pin mini-DIN, RCA x 2, RCA x 3, TOSLINK, mini-phone stereo 3.5 mm
- Connector Location: rear, side
TV Tuner:
- Multi-channel Preview: picture-in-picture (PIP)
- TV Tuner Presence: Yes
- Tuners Configuration: 1x analog, 1x digital
- Digital TV Tuner: ATSC
- Analog TV Tuner: NTSC
- Closed Caption Capability: Yes
- Stereo Reception System: MTS
- Secondary Audio Program (SAP): Yes
Header:
- Brand: Samsung
- Product Line: Samsung
- Model: LN-T5265F
Dimensions and Weight:
- Width: 52.4 in
- Depth: 12.6 in
- Height: 33.6 in
- Weight: 74.74 lbs
- Comments: with stand
Television:
- Type: LCD TV
- Video Interface: HDMI, S-Video, component, composite
- HDMI Ports Qty: 3
- PC Interface: VGA (HD-15)
- Diagonal Class: 52 in
- Diagonal Class (metric): 132 cm
- Resolution: 1920 x 1080
- Display Format: 1080p (Full HD)
- Total Pixels: 3147264
- Response Time: 8 ms
- Image Aspect Ratio: 16:9
- Dynamic Contrast Ratio: 15000:1
- Viewing Angle: 178°
- Viewing Angle (Vertical): 178°
- Display Menu Language: English, French, Spanish
- HDCP Compatible: yes
- Analog Video Input Signals: NTSC
- Input Video Formats: 1080i, 1080p, 720p
- Supported Computer Resolutions: 1024 x 768 (XGA), 1280 x 1024 (SXGA), 1920 x 1080, 640 x 350, 640 x 480 (VGA), 720 x 400, 800 x 600 (SVGA)
- Parental Channel Lock: Yes
- Additional Features: DNIe (Digital Natural Image engine), dynamic contrast
Audio System:
- Sound Output Mode: stereo
- Surround Mode: Yes
- Sound Effects: SRS TruSurround XT
- Equalizer/Bands Qty: Yes (5-band)
- Output Power / Total: 20 Watt
- Speaker System: 2 speakers
- Additional Features: auto volume adjustment, balance control
Speaker System Details:
- Speaker Type: main channel speaker
- Speaker Qty: 2
- Speaker Form Factor: built-in
- Nominal (RMS) Output Power: 10 Watt
Power Device:
- Type: power supply
- Nominal Voltage: AC 120 V
- Frequency Required: 60 Hz
- Power Consumption Operational: 320 Watt
