Door Handle
10 Answers 4 Score |
Water stopped getting dispensed from refrigerator, all of a sudden :( |
1 Answer 0 Score |
Samsung Freezer not freezing (French door) RF4287HARS/XAA |
1 Answer 0 Score |
Owl noise and not dropping ice. |
3 Answers 0 Score |
Freezer Fan Icing Up |
Documents
Parts
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Models
RF4287HABP/XAA, RF4287HABP/XAA-00, RF4287HABP/XAA-01, RF4287HABP/XAA-02, RF4287HABP/XAA-03, RF4287HABP/XAA-04, RF4287HAPN/XAA, RF4287HAPN/XAA-00, RF4287HAPN/XAA-0000, RF4287HAPN/XAA-0001, RF4287HAPN/XAA-01, RF4287HARS XAA, RF4287HARS/XAA, RF4287HARS/XAA-00, RF4287HARS/XAA-0000, RF4287HARS/XAA-0001, RF4287HARS/XAA-01, RF4287HARS/XAA-02, RF4287HARS/XAA-03, RF4287HARS/XAC Show 3 more
RF4287HARS/XAC-00, RF4287HAWP/XAA-00, RF4287HAWPXAA
Background
The Samsung RF4287HA** is a refrigerator model released by Samsung Electronics Co., Ltd. in 2010. This model is categorized under the style of a Bottom Freezer with Ice through-door. It features both drawer and door access to the refrigerator, with the inclusion of an anti-sweat heater switch to control condensation. The appliance utilizes R-410A refrigerant and non-ozone-depleting insulation.
The refrigerator has a total volume of 28.0 cubic feet, with 20.2 cubic feet dedicated to fresh food storage and 7.7 cubic feet for the freezer. It has a height of 70 inches, a width of 33 inches, and a depth of 37 inches. The model operates with an annual energy use of 562.0 kWh/year, which is below the US Federal Standard of 704.0 kWh/year.
Technical Specifications
- Manufacturer: Samsung Electronics Co., Ltd.
- Brand Name: Samsung
- Model Number: RF4287HA**
- Refrigerator Style: Bottom Freezer w/Ice thru-door
- Defrost Type: Automatic
- Type: Refrigerator
- Refrigerator Access: Both Drawer and Door
- Anti-Sweat Heater Switch: Yes
- Compressor Type: Reciprocate
- Rated Voltage/Frequency: AC 115V/60Hz
- Refrigerant Input Amount: 5.64 oz (160g)
- Cooling Method: Indirect Cooling
- Refrigerant Type: R-134a (Non-Ozone Depleting)
- Motor Rated Consumption Power: 140W
- Electric Heater Rated Consumption Power: 340W
- Insulation Type: C-Pentane (Non-Ozone-Depleting)
- Fresh Food Volume (cu ft): 16.28
- Freezer Volume (cu ft): 7.74
- Flex Zone Volume (cu ft): 3.97
- Total Volume (cu ft): 27.98
- Efficiency of Volume: 60%
- External Dimensions (inches):
- Width: 35 3/4 (908mm)
- Depth without Handle: 29 7/8 (760mm)
- Depth with Handle: 36 1/4 (920mm)
- Height without Hinge Cap: 68 1/2 (1740mm)
- Height with Hinge Cap: 69 7/8 (1774mm)
- Weight:
- Net: 362.4 Pounds (164kg)
- With Packing: 402.1 Pounds (182kg)
- Packing Dimensions (inches):
- Width: 38 5/8 (980mm)
- Depth: 36 3/16 (920mm)
- Height: 75 5/8 (1923mm)
- Annual Energy Use (kWh/year): 562.0
- US Federal Standard (kWh/year): 704.0
- Date Added: 2010
- Source: California Energy Commission
