Models
0132301056, 3057, 4185, BAR12, BAR12FU, BAR140, BAR18, BAR32, BAR390, BAR41, BAR42, BAR42E, BAR51, BAR52, BAR6U, BAR8IU, BAR9I, BARM100U, BARM29U, BCM8450UC
Show 272 more BCM8450UC/03, BCM8450UC/04, BCM8450UC/05, BCM8450UC/09, BCO110, BCO120T, BCO130T, BCO264B, BCO320T, BCO330T, BCO430, BCO430BM, BCO432, BCO70, CAM51015B, CAM51025MB, CAM51035M, CC100IU, CM041, CM044, COM530M, COM532M, D14, D31, D4B, D612, D650, D660, D665, D895, D895C, D895UX, D986, DC312T, DC412T, DC412TTC, DC414T, DC514T, DCF210TTC, DCF212T, DCF2210TTC, DCF2212T, DCF6212TTC, DCF6214T, DCM020ST, DCM024BK, DCM025GR, DCM028, DCM029, DCM02BK, DCM02BL, DCM02GR, DCM02OR, DCM02RE, DCM02ST, DCM040, DCM041, DCM043, DCM044, DCM045, DCM047, DCM048, DCM049, DCM04RE, DCM1385OR, DCR902T, DE40P, DE50P, DE650P, DEN500P, DES020, DES020S, DES021, DES023, DES024, DES025, DES027, DES028, DES029, DFH233, DH100P, DH40P, DO1279, DO1280S, DO1289, EAM3200, EAM3300, EAM3400, EAM3400N, EAM3500, EAM3500N, EAM4000, EAM4000B, EAM4400, EAM4500, EC140B, EC140BEXC, EC155, EC220CD, EC260BK, EC270, EC330, EC460, EC5, EC5W, EC6, EC610, EC680BK, EC680BM, EC680BMC, EC680M, EC680M Dedica, EC680R, EC680R Dedica Red, EC685BK, EC685BK Dedica Deluxe, EC685M, EC685M Dedica Deluxe, EC685R, EC685R Dedica Deluxe, EC685W, EC685W Dedica Deluxe, EC700, EC701, EC702, EC710, EC730, EC860, EC885M, EC9155MB, EC9335BK, EC9335M, EC9335R, EC9335REX4, EC9355M, EC9665M, ECAM22110B, ECAM22110SB, ECAM23120SB, ECAM23120SBS11, ECAM23210B, ECAM23210SB, ECAM23260, ECAM23260SB, ECAM23270S, ECAM23450SL, ECAM23460, ECAM25462S, ECAM26455M, ECAM28465B, ECAM28465M, ECAM28465MD, ECAM29034SB, ECAM29043SB, ECAM29063SB, ECAM29084SB, ECAM35020B, ECAM35020W, ECAM35025SB, ECAM35075SI, ECAM37095TI, ECAM44660B, ECAM45055S, ECAM45760B, ECAM46860S, ECO310BK, ECO310R, ECO310W, ECP3120, ECP3220, ECP3220R, ECP3220W, ECP3420, ECP3620, ECP3630, EDG455, EDG656TEX1, EMF2BK, EMFIBK, EMK6, EMK6A, EMK6YL, EN267BAE, EN520B, EN520BEX1, EN520R, EN560S, EN680M, EN750MB, EO12001B, EO1200B, EO1238, EO1251, EO1258, EO1260, EO1270, EOP2046, ESAM04110B, ESAM04110S, ESAM2000, ESAM3300, ESAM3300EXD, ESAM3300EXHD, ESAM3300S, ESAM3500, ESAM3500N, ESAM4400, ESAM4500, ESAM5400, ESAM5500, ESAM5500B, ESAM5500M, ESAM5600, ESAM5600SL, ESAM6600, ESAM6620, ESAM6700, ESAM6900, ESAM6900M, FH1130/1BK, FH1163/1BK, FH1363/1BK, ICM17270, KF180BLACK, KF180TITAN, KF180WHITE, KF510, KF5350BK, KF5350WH, KF550, KF5650BK, KF580, KF600, KF600BLACK, KF600WHITE, KF6031BK, KF6050WH, KF7000BK, KF7070SI, KF7150BK, KF7155, KF7170BK, KF7170SI, KF7175, KF7370SI, KF9050BK, KF9070SI, KF9150BK, KF9150WH, KF9170SI, KG521M, KMM30BLACK, KMM30WHITE, KSM2, KSM4, M810, M850, M870220W, M870280W, M880220W, M880280W, MR310, MR330, MR400, MR430, PACT100P, PACT110P, PACT140HPEC, PENTA, TA1200, TA1400, VVX1470GA
General
Coffee makers are appliances designed for brewing coffee conveniently at home or in commercial settings. They come in various types, each employing different methods to extract flavors from coffee grounds.
Types
Drip Coffee Makers
Pour-Over Coffee Makers
Pour-over coffee makers are manual brewing devices that allow coffee enthusiasts to have more control over the brewing process. The basic design consists of a funnel or cone-shaped dripper, which holds a paper or metal filter. Ground coffee is placed in the filter, and hot water is poured over it in a slow, controlled manner.
Auto-Drip Coffee Makers
Auto drip coffee makers, also known as automatic drip coffee makers, are popular electric brewing devices designed for convenience and ease of use. Auto-drip coffee makers automate the brewing process. You add water to a reservoir, place ground coffee in a filter basket, and turn on the machine. The water is heated and then dripped over the coffee grounds. The brewed coffee flows through a filter into a pot or carafe, which sits on a warming plate to keep the coffee hot. Some models offer features like adjustable brewing strength and time delay.
Steeping Coffee Makers
Cold Brew Coffee Makers
Cold brew coffee makers are devices designed for the simple and efficient preparation of cold brew coffee. They typically involve steeping coarsely ground coffee beans in cold or room temperature water for an extended period, usually 12-24 hours. The result is a smooth, less acidic coffee concentrate that can be diluted with water or milk before consumption. These machines often feature a filter or mesh system to separate the grounds, making the brewing process convenient and mess-free.
French Presses
A French press is a simple and effective coffee brewing device. It consists of a cylindrical glass or stainless steel container with a plunger and a metal mesh filter. To make coffee, coarsely ground coffee beans are steeped in hot water within the press. After a few minutes, the plunger is pressed down, separating the grounds from the brewed coffee. This method allows for a full-bodied and flavorful cup, as the coffee grounds remain in direct contact with the water during the brewing process.
Turkish Coffee Makers
Turkish coffee makers, known as cezve or ibrik, are traditional brewing vessels designed for making Turkish coffee. Typically made of copper or brass, these small pots have a long handle and a wide base. Finely ground coffee, water, and sugar (optional) are combined in the cezve and heated over low flame. The unique brewing process involves bringing the mixture to a near-boil multiple times, creating a strong, concentrated coffee with a thick foam known as "kaymak." The finely ground coffee grounds settle at the bottom, offering a distinctive and rich coffee experience.
Pressure-Based Coffee Makers
AeroPress
The AeroPress is a compact coffee maker designed for simplicity and versatility. It consists of a cylindrical chamber with a plunger and a filter cap. To brew coffee, users place coffee grounds and hot water in the chamber, stir, attach the filter cap, and press the plunger to extract the coffee. Its unique design allows for quick and easy brewing, and it's known for producing a smooth and rich cup of coffee with control over brewing variables. The AeroPress is popular among coffee enthusiasts for its portability, affordability, and ability to experiment with different brewing techniques.
Moka Pot
A Moka Pot is a stovetop coffee maker that brews strong and flavorful coffee by passing boiling water pressurized by steam through ground coffee. It consists of a bottom chamber for water, a middle funnel for coffee grounds, and a top chamber for the final brew. As water heats up, pressure forces it through the coffee grounds, producing a rich and concentrated coffee known as Moka. The process is simple, quick, and popular for its ability to create a robust coffee with a distinctive taste, somewhat similar to espresso.
Single-Serve Coffee Machines
Single serve coffee makers are compact, convenient appliances designed for brewing individual servings of coffee. They utilize pre-packaged coffee pods or capsules, allowing users to quickly and easily prepare a single cup of coffee with minimal effort and mess. These machines offer a variety of coffee options, catering to different tastes, and are favored for their simplicity and time efficiency.
Espresso Machines
Espresso makers, commonly known as espresso machines, are specialized coffee devices designed to brew concentrated coffee by forcing hot water through finely-ground coffee beans. They operate under high pressure, typically around 9 bars, to extract rich flavors and aromatic compounds from the coffee grounds. Espresso is characterized by its strong and bold taste, as well as a layer of crema, a creamy foam that forms on top. These machines come in various types, including manual, semi-automatic, and automatic, offering users different levels of control over the brewing process.
Fully Automatic Coffee Machines
Fully automatic coffee machines are advanced appliances that streamline the coffee-making process. These machines handle everything from grinding coffee beans to brewing, eliminating the need for manual intervention. Users can customize factors like grind size, coffee strength, and beverage type, as these machines can produce a variety of beverages, including espresso, cappuccino, latte, and regular coffee. With built-in grinders and automated brewing systems, these they offer convenience and consistency, delivering freshly brewed coffee with minimal effort.
Percolators
Percolator coffee makers are traditional brewing devices that consist of a pot, a central tube, and a perforated basket. Water in the pot is heated, and the resulting pressure forces it up the tube and over coffee grounds in the basket. The brewed coffee then flows back into the pot, creating a continuous cycle until the desired strength is achieved. Percolators were popular in the past but have largely been replaced by drip coffee makers due to differences in brewing methods and taste preferences.
Siphon Coffee Makers
Siphon coffee makers, also known as vacuum coffee brewers, employ a visually captivating and physics-based brewing method. Consisting of two chambers, water is heated in the lower chamber, creating vapor pressure that forces water to move to the upper chamber where coffee grounds are placed. As the heat is turned off, brewed coffee is drawn back into the lower chamber due to a vacuum effect. This process results in a unique and aromatic coffee with a smooth and clean taste, highlighting the flavors of the beans.
Additional Information
Coffee Makers on Wikipedia
Andrew Optimus Goldheart
509,160 Reputation
407 Guides authored
iFixit Member of iFixit
Staff
121 Members
19,776 Guides authored
Past 24 Hours: 124
Past 7 Days: 812
Past 30 Days: 3,656
All Time: 134,527
