1999 GMC Suburban Brake Light Replacement
  1. 1999 GMC Suburban Brake Light Replacement, Brake Light: step 1, image 1 of 3 1999 GMC Suburban Brake Light Replacement, Brake Light: step 1, image 2 of 3 1999 GMC Suburban Brake Light Replacement, Brake Light: step 1, image 3 of 3
    • Before you begin, turn off your car, put it in park, and engage the emergency brake.
    • Select the side of the car you would like to work on first.
    • Open the trunk doors.
  2. 1999 GMC Suburban Brake Light Replacement: step 2, image 1 of 3 1999 GMC Suburban Brake Light Replacement: step 2, image 2 of 3 1999 GMC Suburban Brake Light Replacement: step 2, image 3 of 3
    • These two holes have screws inside of them, so unscrew them to get the brake light out.
    • The screws that will be removed for this step are "Round washer head pozi-drive tapping screw tail lamp assembly M4.2-1.41 x 20mm".
  3. 1999 GMC Suburban Brake Light Replacement: step 3, image 1 of 3 1999 GMC Suburban Brake Light Replacement: step 3, image 2 of 3 1999 GMC Suburban Brake Light Replacement: step 3, image 3 of 3
    • When removing the tail light there are little hooks with holes that are used to hold them in place as shown in the first photo.
    • The tail should already be loose from the previous step so pull it out slowly by turning it on its side and then pulling forward.
    • Use the 7 mm socket to unscrew the two bolts securing the brake light housing to the tail light assembly.
    • The screws in this step are "Rexka 30pcs M4.2-1.41 x 20mm".
  4. 1999 GMC Suburban Brake Light Replacement: step 4, image 1 of 2 1999 GMC Suburban Brake Light Replacement: step 4, image 2 of 2
    • After taking off the screws, take the brake lights out and find which light isn't working by stepping on the brake.
  5. 1999 GMC Suburban Brake Light Replacement: step 5, image 1 of 1
    • With the actual light, unplug them by pulling them out but not with too much force.
    • Plug the new light bulb(s) in place of the ones that don't work.
    • Please be careful with how you remove the bulbs because they are made of glass.
  6. 1999 GMC Suburban Brake Light Replacement: step 6, image 1 of 2 1999 GMC Suburban Brake Light Replacement: step 6, image 2 of 2
    • Now put everything back together and put all the screws back on.
    • The steps are the same on both sides and is a fairly simple and fast process.
Marcos Shipley
133 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 25
All Time: 143
