2003 Toyota Solara Tail Light Replacement
  1. 2003 Toyota Solara Tail Light Replacement, Tail Light: step 1, image 1 of 1
    • Park the vehicle and turn off the engine.
    • Step on the brake pedal to confirm whether or not the tail light is responsive.
  2. 2003 Toyota Solara Tail Light Replacement: step 2, image 1 of 3 2003 Toyota Solara Tail Light Replacement: step 2, image 2 of 3 2003 Toyota Solara Tail Light Replacement: step 2, image 3 of 3
    • Reach underneath the steering wheel. Then, place your hand to the left to remove the fuse box cover.
  3. 2003 Toyota Solara Tail Light Replacement: step 3, image 1 of 2 2003 Toyota Solara Tail Light Replacement: step 3, image 2 of 2
    • Reference the fuse box guide on the back of the cover.
    • Locate the fuse number that corresponds to the tail light (2nd column, last row).
    • Replace the tail lamp if the fuse is still functional.
  4. 2003 Toyota Solara Tail Light Replacement: step 4, image 1 of 2 2003 Toyota Solara Tail Light Replacement: step 4, image 2 of 2
    • Open the vehicle's trunk.
    • Unscrew the plastic fastenings located inside the trunk.
    • Detach the panel covering the tail light.
  5. 2003 Toyota Solara Tail Light Replacement: step 5, image 1 of 3 2003 Toyota Solara Tail Light Replacement: step 5, image 2 of 3 2003 Toyota Solara Tail Light Replacement: step 5, image 3 of 3
    • Untwist the wired socket to expose the lamp bulb.
    • Check the bulb for discoloration (if it is clouded, replace the bulb).
  6. 2003 Toyota Solara Tail Light Replacement: step 6, image 1 of 2 2003 Toyota Solara Tail Light Replacement: step 6, image 2 of 2
    • Insert the new bulb into the socket.
    • Push until there is an audible "click".
To reassemble the tail lamp, follow these instructions in reverse order.
2 other people completed this guide.
Melissa Spinali
107 Reputation
1 Guide authored
UC Davis, Team S2-G2, Cole Spring 2017 Member of UC Davis, Team S2-G2, Cole Spring 2017
UCD-COLE-S17S2G2
3 Members
1 Guide authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 16
Past 30 Days: 61
All Time: 2,839
