2014-2020 Mercedes-Benz C-Class W205 COMAND Centre-Dial Touchpad Replacement
  1. 2014-2020 Mercedes-Benz C-Class W205 COMAND Centre-Dial Touchpad Replacement, COMAND Centre-Dial Touchpad: step 1, image 1 of 3 2014-2020 Mercedes-Benz C-Class W205 COMAND Centre-Dial Touchpad Replacement, COMAND Centre-Dial Touchpad: step 1, image 2 of 3 2014-2020 Mercedes-Benz C-Class W205 COMAND Centre-Dial Touchpad Replacement, COMAND Centre-Dial Touchpad: step 1, image 3 of 3
    • Start by pressing down on the button that opens the center arm-rest.
    • Pop each side of the silver trim using the trim removal tool or a plastic opening tool.
    • Remove the silver trim.
  2. 2014-2020 Mercedes-Benz C-Class W205 COMAND Centre-Dial Touchpad Replacement: step 2, image 1 of 3 2014-2020 Mercedes-Benz C-Class W205 COMAND Centre-Dial Touchpad Replacement: step 2, image 2 of 3 2014-2020 Mercedes-Benz C-Class W205 COMAND Centre-Dial Touchpad Replacement: step 2, image 3 of 3
    • Remove the two 20 mm screws securing the center console with a T20 Torx screwdriver.
  3. 2014-2020 Mercedes-Benz C-Class W205 COMAND Centre-Dial Touchpad Replacement: step 3, image 1 of 2 2014-2020 Mercedes-Benz C-Class W205 COMAND Centre-Dial Touchpad Replacement: step 3, image 2 of 2
    • Make sure there aren't any loose articles in the center storage compartment.
    • Lift the end of the center-console and flip it to reveal the undercarriage of the center-dial touchpad and its wirings.
  4. 2014-2020 Mercedes-Benz C-Class W205 COMAND Centre-Dial Touchpad Replacement: step 4, image 1 of 3 2014-2020 Mercedes-Benz C-Class W205 COMAND Centre-Dial Touchpad Replacement: step 4, image 2 of 3 2014-2020 Mercedes-Benz C-Class W205 COMAND Centre-Dial Touchpad Replacement: step 4, image 3 of 3
    • Press your thumb on the safety tab to remove each blue connection.
  5. 2014-2020 Mercedes-Benz C-Class W205 COMAND Centre-Dial Touchpad Replacement: step 5, image 1 of 3 2014-2020 Mercedes-Benz C-Class W205 COMAND Centre-Dial Touchpad Replacement: step 5, image 2 of 3 2014-2020 Mercedes-Benz C-Class W205 COMAND Centre-Dial Touchpad Replacement: step 5, image 3 of 3
    • Press down on the center of the white connection in the middle and slide the safety latch to the left to pull out the main white connection.
  6. 2014-2020 Mercedes-Benz C-Class W205 COMAND Centre-Dial Touchpad Replacement: step 6, image 1 of 3 2014-2020 Mercedes-Benz C-Class W205 COMAND Centre-Dial Touchpad Replacement: step 6, image 2 of 3 2014-2020 Mercedes-Benz C-Class W205 COMAND Centre-Dial Touchpad Replacement: step 6, image 3 of 3
    • Remove the two 15 mm T15 Torx screws holding the center-dial touchpad.
    • Firmly press the center-dial touchpad out to remove the unit.
5 other people completed this guide.
Amin Fadhil
267 Reputation
1 Guide authored
One Comment
This is great thanks, made an account to say thank you
Nolan Scott - Reply
Past 24 Hours: 10
Past 7 Days: 44
Past 30 Days: 243
All Time: 11,349
