2018 Dodge Charger Headlight Bulb Replacement
  1. 2018 Dodge Charger Headlight Bulb Replacement, Prerequisites: step 1, image 1 of 1
    • Before you begin, make sure the vehicle is turned off and placed in park with the parking brake engaged.
  2. 2018 Dodge Charger Headlight Bulb Replacement, Open the hood: step 2, image 1 of 3 2018 Dodge Charger Headlight Bulb Replacement, Open the hood: step 2, image 2 of 3 2018 Dodge Charger Headlight Bulb Replacement, Open the hood: step 2, image 3 of 3
    • Open the hood by pulling the release lever inside the vehicle, located on the driver's side by the parking brake.
    • Once pulled, you will hear the sound of the hood pop open.
  3. 2018 Dodge Charger Headlight Bulb Replacement, Pull the lever, lift the hood: step 3, image 1 of 3 2018 Dodge Charger Headlight Bulb Replacement, Pull the lever, lift the hood: step 3, image 2 of 3 2018 Dodge Charger Headlight Bulb Replacement, Pull the lever, lift the hood: step 3, image 3 of 3
    • Carefully place your hands under the hood, towards the middle of the car.
    • When you feel the lever, push it to the left using your left hand and slowly push the hood up with your right hand.
    • If your Charger has or requires a stand, prop it up.
    • This model of Charger does not require a stand to hold the hood. It will automatically hold on its own.
  4. 2018 Dodge Charger Headlight Bulb Replacement, Unscrew the headlight cap: step 4, image 1 of 3 2018 Dodge Charger Headlight Bulb Replacement, Unscrew the headlight cap: step 4, image 2 of 3 2018 Dodge Charger Headlight Bulb Replacement, Unscrew the headlight cap: step 4, image 3 of 3
    • On the passenger side of the car, unscrew the cap covering the headlight compartment.
    • Remove the cap from the headlight.
    • Use gloves to protect your hands.
  5. 2018 Dodge Charger Headlight Bulb Replacement, Remove the old bulb: step 5, image 1 of 2 2018 Dodge Charger Headlight Bulb Replacement, Remove the old bulb: step 5, image 2 of 2
    • Once you remove the cap, you will see the current bulb that is installed.
    • Slowly twist the bulb clockwise, and remove it from the compartment.
  6. 2018 Dodge Charger Headlight Bulb Replacement, Detach the bulb and adapter: step 6, image 1 of 3 2018 Dodge Charger Headlight Bulb Replacement, Detach the bulb and adapter: step 6, image 2 of 3 2018 Dodge Charger Headlight Bulb Replacement, Detach the bulb and adapter: step 6, image 3 of 3
    • Unplug the bulb from the adapter.
    • Lift the lever and carefully detach it.
    • Place the bulb in a safe area away from the vehicle.
  7. 2018 Dodge Charger Headlight Bulb Replacement, Reconnect a new bulb to the adapter: step 7, image 1 of 2 2018 Dodge Charger Headlight Bulb Replacement, Reconnect a new bulb to the adapter: step 7, image 2 of 2
    • Connect a new light bulb to the adapter.
  8. 2018 Dodge Charger Headlight Bulb Replacement, Lock the bulb and cap in place: step 8, image 1 of 3 2018 Dodge Charger Headlight Bulb Replacement, Lock the bulb and cap in place: step 8, image 2 of 3 2018 Dodge Charger Headlight Bulb Replacement, Lock the bulb and cap in place: step 8, image 3 of 3
    • Align the bulb to the shape of the hole and turn clockwise to safely lock.
    • After installation, you will see cables sticking out. You can manage this by fitting it in the compartment.
    • Place the cap back on the compartment and tightly seal it.
  9. 2018 Dodge Charger Headlight Bulb Replacement, Accessing the driver's side bulb: step 9, image 1 of 2 2018 Dodge Charger Headlight Bulb Replacement, Accessing the driver's side bulb: step 9, image 2 of 2
    • To access the driver's side lightbulb, you have to remove the air intake from under the hood.
  10. 2018 Dodge Charger Headlight Bulb Replacement, Loosen the intake bolts: step 10, image 1 of 3 2018 Dodge Charger Headlight Bulb Replacement, Loosen the intake bolts: step 10, image 2 of 3 2018 Dodge Charger Headlight Bulb Replacement, Loosen the intake bolts: step 10, image 3 of 3
    • Loosen two bolts using a 1/4 ratchet with a 5/16 inch socket.
    • Gently loosen the bolt. Loosening it too quickly may result in the screw falling into the engine compartment.
  11. 2018 Dodge Charger Headlight Bulb Replacement, Remove the bolts manually: step 11, image 1 of 2 2018 Dodge Charger Headlight Bulb Replacement, Remove the bolts manually: step 11, image 2 of 2
    • Once the screw is loosened, use your hand to continue the process.
  12. 2018 Dodge Charger Headlight Bulb Replacement, Detach the intake tube: step 12, image 1 of 2 2018 Dodge Charger Headlight Bulb Replacement, Detach the intake tube: step 12, image 2 of 2
    • Loosen the screw attached to the ring.
    • Detach the tube from the intake.
    • Do not remove the ring from the tube.
  13. 2018 Dodge Charger Headlight Bulb Replacement, Lift the intake out: step 13, image 1 of 3 2018 Dodge Charger Headlight Bulb Replacement, Lift the intake out: step 13, image 2 of 3 2018 Dodge Charger Headlight Bulb Replacement, Lift the intake out: step 13, image 3 of 3
    • Grab the intake with both hands and gently lift upwards.
    • Place the intake safely on top of the main engine block.
  14. 2018 Dodge Charger Headlight Bulb Replacement, Find the headlight compartment: step 14, image 1 of 2 2018 Dodge Charger Headlight Bulb Replacement, Find the headlight compartment: step 14, image 2 of 2
    • Once the intake is safely removed, you can access the headlight compartment.
  15. 2018 Dodge Charger Headlight Bulb Replacement, Replace the bulb: step 15, image 1 of 3 2018 Dodge Charger Headlight Bulb Replacement, Replace the bulb: step 15, image 2 of 3 2018 Dodge Charger Headlight Bulb Replacement, Replace the bulb: step 15, image 3 of 3
    • Remove the light bulb by lifting on the small lever.
    • Connect the new headlight bulb and firmly align the bulb to the compartment.
    • Double check that the bulb is properly installed and connected. If it is not installed properly, you will have to remove the intake again.
  16. 2018 Dodge Charger Headlight Bulb Replacement, Realign the air intake: step 16, image 1 of 2 2018 Dodge Charger Headlight Bulb Replacement, Realign the air intake: step 16, image 2 of 2
    • Place the intake back in its original place.
    • Align the bottom of the intake to its original spot as seen in the picture.
  17. 2018 Dodge Charger Headlight Bulb Replacement, Tighten the intake screw: step 17, image 1 of 2 2018 Dodge Charger Headlight Bulb Replacement, Tighten the intake screw: step 17, image 2 of 2
    • Place the bolt and ring back on the intake.
    • Tighten the screw with your hands and finish securing the screw using the 1/4 ratchet and the 5/16 in socket.
  18. 2018 Dodge Charger Headlight Bulb Replacement, Reattach the intake tube: step 18, image 1 of 3 2018 Dodge Charger Headlight Bulb Replacement, Reattach the intake tube: step 18, image 2 of 3 2018 Dodge Charger Headlight Bulb Replacement, Reattach the intake tube: step 18, image 3 of 3
    • Firmly attach the tube to the intake.
    • Tighten the screw using the 1/4 ratchet with the 5/16 inch socket.
    • Close the hood of the vehicle.
    • Before closing the hood, make sure the engine compartment is clear of obstruction.
  19. 2018 Dodge Charger Headlight Bulb Replacement, Test the new lightbulbs: step 19, image 1 of 1
    • Power on the vehicle to ensure the new headlight bulbs are successfully working.
Congratulations, you've successfully replaced both lightbulbs!
Anthony Does Repairs
313 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 12
Past 7 Days: 86
Past 30 Days: 413
All Time: 13,127
