ASUS Chromebook C300MA-DH01 Battery Replacement
  1. ASUS Chromebook C300MA-DH01 Battery  Replacement, Battery: step 1, image 1 of 1
    • Flip the Chromebook over so the bottom of the device is facing up.
  2. ASUS Chromebook C300MA-DH01 Battery  Replacement: step 2, image 1 of 2 ASUS Chromebook C300MA-DH01 Battery  Replacement: step 2, image 2 of 2
    • Using the JIS-J0 Screwdriver, remove the following screws from the bottom
    • (5) Five 6mm screws
    • (6) Six 8mm screws
  3. ASUS Chromebook C300MA-DH01 Battery  Replacement: step 3, image 1 of 3 ASUS Chromebook C300MA-DH01 Battery  Replacement: step 3, image 2 of 3 ASUS Chromebook C300MA-DH01 Battery  Replacement: step 3, image 3 of 3
    • Gently wedge the spudger in between the bottom of the device and the keyboard, and carefully pry the cover open. Then, carefully lift up on keyboard.
  4. ASUS Chromebook C300MA-DH01 Battery  Replacement: step 4, image 1 of 3 ASUS Chromebook C300MA-DH01 Battery  Replacement: step 4, image 2 of 3 ASUS Chromebook C300MA-DH01 Battery  Replacement: step 4, image 3 of 3
    • Gently detach connecting cables:
    • Carefully flip up the large black tab.
    • Carefully flip up small white tab.
    • Remove the corresponding black cable.
    • Remove the corresponding white cable.
    • The keyboard will be fully detached at this point.
  5. ASUS Chromebook C300MA-DH01 Battery  Replacement: step 5, image 1 of 2 ASUS Chromebook C300MA-DH01 Battery  Replacement: step 5, image 2 of 2
    • Using the JIS-J0 Screwdriver, remove the (6) six 6 mm screws from the battery.
  6. ASUS Chromebook C300MA-DH01 Battery  Replacement: step 6, image 1 of 1
    • Using the plastic opening tool, gently push the connector tab away from the battery to detach the cable.
    • The battery will be fully detached at this point. Carefully lift it out of the device.
amer khalil
101 Reputation
1 Guide authored
USF Tampa, Team S2-G5, Passmore Fall 2017 Member of USF Tampa, Team S2-G5, Passmore Fall 2017
USFT-PASSMORE-F17S2G5
3 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 10
All Time: 205
